It is currently Sat Jul 19, 2025 3:39 pm
PostPosted: Sun Aug 30, 2015 5:11 pm
as a mechanical novice I feel pretty good about myself. Had a few issues but nothing a bit of swearing couldn't fix. I left it sitting a bit higher than normal (5 fingers) just to be safe, but Just took it out of the garage and down the driveway and the right side went down to about 1 finger between wheel and arch. Mustn't have tightened something. Will check tomorrow.
I have a question. One of the knuckle joints didn't seem to go into the cup flush. Will this push in as I drive around or just stuff up and I'll have to get a new one?
PostPosted: Sun Aug 30, 2015 5:23 pm
If it has had a stuffed one for a while the hole might be worn a bit, it'll settle in.
