Pull Switch??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90405
Page 1 of 2
Author:  Jenk [ Sun Aug 30, 2015 5:34 pm ]
Post subject:  Pull Switch??
Can someone please advise what the pull switch on far right of switch panel is for?
Author:  simon k [ Sun Aug 30, 2015 5:39 pm ]
Post subject:  Re: Pull Switch??
is it a switch or a cable?
doesn't look like a standard one anyway...
Author:  peterb [ Sun Aug 30, 2015 5:40 pm ]
Its not original, is it connected?
Author:  Jenk [ Sun Aug 30, 2015 5:49 pm ]
Its a switch pull on push off it has a wire that feeds of the light switch, if its not standard what would normally be in this position?
Author:  Jenk [ Sun Aug 30, 2015 5:52 pm ]
Yes its connected one feeds off the light switch another is a loose red wire which goes nowhere would it be for spotlights possibly?? if it not original what would normally occupy this position?
Author:  stuvz [ Sun Aug 30, 2015 6:01 pm ]
cruise control?
Author:  phillb [ Sun Aug 30, 2015 6:02 pm ]
Choke or heater control depending on year.
Author:  stuvz [ Sun Aug 30, 2015 6:08 pm ]
correct me if i'm wrong but it doesn't look like you have a heater.
Author:  Jenk [ Sun Aug 30, 2015 6:10 pm ]
definitely not choke... its on the far left! heater possibly :? but is the switch original if not what should it look like?
its a 65 or 66 thereabouts
Author:  Jenk [ Sun Aug 30, 2015 6:11 pm ]
stuvz wrote:
cruise control?
Ha I wish :lol:
Author:  Jenk [ Sun Aug 30, 2015 6:14 pm ]
I removed the heater to sort the messy wiring out, the heater is a cooper s one which isn't original, is this the location where the heater switch would be?
Author:  goodie [ Sun Aug 30, 2015 6:18 pm ]
Yes .
Author:  Jenk [ Sun Aug 30, 2015 6:21 pm ]
goodie wrote:
Yes .
Thanks goodie, would the heater switch be this type i.e pull push type??
Author:  goodie [ Sun Aug 30, 2015 6:38 pm ]
Yes , not sure what model your car is, but the Mini K , Cooper S is in that position , albeit a different looking knob on the cable , but yes they are push / pull .
Author:  AJ [ Sun Aug 30, 2015 7:03 pm ]
Minis didn't have push pull electrical switches and the 'heater switch' for the Cooper S is actually a control cable located on the left side for the Mk1 and right side for the Mk2 ,with the choke on other side. The Cooper S heater has an on/off switch mounted on the unit for the fan. Mini Deluxe ,Matic,Mini Minor etc usually have the windscreen washer pump mounted on right side ,with choke a T piece to the right of that under dash, and if fitted with a heater, the control is on left side
