I had a 200KMH `Smiths' (aftermarket) speedo in my Mini.
This one:
http://minispares.com/product/Classic/G ... o%20searchIt has now done around 20,000KM. For the last year or so the speed indication has crept lower and lower at a given speed. However the odometer still reads correctly. Eventually I fitted a 140KMH Moke one instead.
Today I took the 200KMH one to an instrument repairer (who shall remain nameless) for a repair quote.
He tested it, its speed @ 60KMH was indicating 17KMH low. Then tested at 100KMH? it was much further out.
His comment:
" These speedos made since Smiths closed down are not well made, there is little or no lube held in the spindle bush, so they either wear bad (like mine has), or they seize up". Not worth fixing, he reckons.
I had a 130MPH version of this same speedo, it worked just fine for nearly 30,000 MILES until I swapped it out for the 200KMH one.
I know Danny_ has just seized his 200KMH one of the same type, so my question: how common is this? Is it worth just shelling out for another new one, and hoping for the best?
Or can other places fix them so they last, at a reasonable price?
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
