Subframe Bolt Q's https://www.ausmini.com/forums/viewtopic.php?f=2&t=9045 |
Page 1 of 2 |
Author: | rampage101 [ Wed Jul 13, 2005 4:26 pm ] |
Post subject: | Subframe Bolt Q's |
Well, on the weekend I decided I'd put a rear subby back in the mini to help when moving it around the garage. I 've got one side of the frame bolted in, couldn't quite get all the bolts on the other. Anyway, the front long bolt that horizontally bolts into the body is just turning, ie. the thread on the nut/shell is stripped, so it won't do up tight. Any solutions? Snapped a bolt in the hole next to the other 1 ^. |
Author: | Harley [ Wed Jul 13, 2005 4:31 pm ] |
Probably should replace with all new nuts, bolts and washers. Why wouldn't the subframe be lining up? Is it off another car? |
Author: | rampage101 [ Wed Jul 13, 2005 4:41 pm ] |
Yeh, the subframe is off an 850 that I've got. I just need to jack the one of the front corners up into position, I just can't locate the bolt hole with the bolt where it is. Edit. This is all temporary, I will be using all new bolts etc. I'll possibly get a solid subframe mounting kit. |
Author: | Harley [ Wed Jul 13, 2005 4:48 pm ] |
Ypu'd be better getting the new bolts now, then you'll have them for later, and you'll have less trouble than say a head breaking off with the old ones. |
Author: | gafmo [ Wed Jul 13, 2005 10:51 pm ] |
get new bolts....If the old bolt is stuck in...you may have to redrill and tap a larger size Also if replaceing.....put some copper grease on them so they wont rust as yours may have ![]() |
Author: | J_A_M [ Thu Jul 14, 2005 8:46 am ] |
Post subject: | Re: Subframe Bolt Q's |
rampage101 wrote: Anyway, the front long bolt that horizontally bolts into the body is just turning, ie. the thread on the nut/shell is stripped, so it won't do up tight. Any solutions?.
Sounds like the captive nut is threaded! ![]() ![]() Hmmm......I don't know what to suggest, appart from DO NOTHING UNTIL YOU CAN DO THE RIGHT THING! |
Author: | rampage101 [ Thu Jul 14, 2005 9:19 am ] |
?? As in its a nut welded to the body on the inside of the sill? In which case, can you get to it from just taking off the outer sill? |
Author: | J_A_M [ Thu Jul 14, 2005 9:43 am ] |
I have never removed a sill, but my guess is YES. |
Author: | rampage101 [ Thu Jul 14, 2005 9:47 am ] |
Is this an indication that I should cease work on this shell and get my other shell sandblasted? ![]() Argrrrrrrrrrrrrrrrrrrrrrrrrghrghrghrgrhghr! |
Author: | manofaus [ Thu Jul 14, 2005 10:44 am ] |
you could always use a helicoil. Kits are about 30 bucks. |
Author: | J_A_M [ Thu Jul 14, 2005 11:03 am ] |
mmm yes...good point! |
Author: | MiNi MuLiShA [ Thu Jul 14, 2005 11:07 am ] |
if your clever... you could grind (cut) out the old captive nut.. get the right nut to replace it.. weld it to a bit of steel/sheet steel... and weld it back into place... thats what i'd be doing before sandblasting another shell ![]() -Cam ![]() |
Author: | Harley [ Thu Jul 14, 2005 11:47 am ] |
You could just re tap it one size larger, then use a bigger bolt. |
Author: | MiNi MuLiShA [ Thu Jul 14, 2005 11:50 am ] |
Harley wrote: You could just re tap it one size larger, then use a bigger bolt.
that would be the easiest way by far... for the broken bolt one. but thers still the turning captive nut ![]() it sounds like a horrible job ![]() -Cam |
Author: | Harley [ Thu Jul 14, 2005 12:13 pm ] |
Just poke a mig end up there, give it a quick zap, problem fixed. |
