Miss Fire!! https://www.ausmini.com/forums/viewtopic.php?f=2&t=9048 |
Author: | ryan [ Wed Jul 13, 2005 6:07 pm ] |
Post subject: | Miss Fire!! |
Hi everyone, My car is missfiring when i first start it up in the cold, sounds like its only running on three cylinders. But once the car warms up its fine. To me it seems like a problem with one of the spark plugs ![]() Any suggestions? Cheers in advanced |
Author: | scotty [ Wed Jul 13, 2005 7:24 pm ] |
Pull out one by one and check by holding lead close to the plug listening for a spark. |
Author: | brickworx [ Wed Jul 13, 2005 7:53 pm ] |
Check your plug gap. should be 25 thou. and check your choke is working |
Author: | SnoBall [ Thu Jul 14, 2005 9:38 pm ] |
I had the same prob, would run on 2-3 cylinders untill warm, then i found my choke cable a little stuffed, didnt go in fully. shes all good now, use choke only to start car, turn off emediatly after start-up, All 4 cylinders work fine! |
Author: | willy [ Thu Jul 14, 2005 9:42 pm ] |
My quick remedy for morning start misfires is to hold the throttle on until valve bounce is acheived... then back off. Works fine every morning. |
Author: | SnoBall [ Thu Jul 14, 2005 10:01 pm ] |
Author: | willy [ Thu Jul 14, 2005 10:19 pm ] |
![]() Please nobody try this. Ar the poor valves ![]() ![]() |
