It is currently Wed Jul 30, 2025 6:27 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: PCV valve... UPDATE 2
PostPosted: Fri Jun 10, 2005 3:43 pm
Hey all, I put the Smiths PCV valve back on Ha-Ha's Weber manifold for his blueslip (gotta look legit, hey- no plastic vent bottle... :wink: ) and guess what, he goes even harder!.
Hmmm.... very interestingggggggg... Ill leave it on until next Wakefield Pk track day... :D
Last edited by drmini in aust on Mon Jul 11, 2005 7:17 pm, edited 2 times in total.
PostPosted: Fri Jun 10, 2005 3:50 pm
mmmm what would make it go harder kev?? stop an air leak or something maybe??? How did it go today with the blueslip, did my mate give you any hassles :D ?
1974 Moke - 998cc
PostPosted: Fri Jun 10, 2005 3:55 pm
It pulls a vacuum on the crankcase. Vizard says this can increase power, I forget why..
I think it's a bit leaner down low- more of a pig when cold, even though I opened up the 1-2 idle screw 2 turns to compensate... :wink:
No probs getting blueslip.. but I haven't been to RTA yet! :lol:
PostPosted: Fri Jun 10, 2005 4:57 pm
I was just reading vizard about this last night. If you create a vacuum in the crank case you can get up to 2hp on the top end. I can't remember what he calls it...
PostPosted: Fri Jun 10, 2005 5:08 pm
Vacusump, grasshopper... :wink:
PostPosted: Fri Jun 10, 2005 5:57 pm
PCV:
The PCV Valve recirculates partially burned gases from the engine?s crankcase to the combustion chamber. This improves fuel economy and reduces engine emissions while preventing the buildup of harmful sludge and corrosion. PCV stands for Positive Crankcase Ventilation.
Hmm...is this the same charcoal cannister on late cars? or something different?
PostPosted: Fri Jun 10, 2005 6:22 pm
Hey Doc, any chance of getting a pic of your PCV setup?
Jonathan
PostPosted: Fri Jun 10, 2005 7:07 pm
Tomorrow. :wink:
It's just a normal Smiths PCV off a Cooper S, plumbed into one inlet port. Probably should be into both, but to do that I'd need more fittings. :lol:
PostPosted: Fri Jun 10, 2005 7:25 pm
heres mine althought not on a weber its in between the 2 carbies the round thing
PostPosted: Fri Jun 10, 2005 7:30 pm
pity it's ugly...
damn non bling :lol: won't matter for Ha-Ha though :P
PostPosted: Fri Jun 10, 2005 7:39 pm
Mini Mad wrote:
pity it's ugly...
haha, I'll paint it Cooper S green then. Match the motor... which IS prettier than yours! :P
PostPosted: Fri Jun 10, 2005 7:53 pm
haha..touche :oops:
Not for long though 8) the new motor is going to get bling treatment ;)
PostPosted: Fri Jun 10, 2005 8:00 pm
The PCV is not fugly at all and can be made very bling - its an alloy body and a steel cover so read polish, and polish some more than was and a bit more polish and clear coat the mofo - better than 50cents' dentures.
PostPosted: Fri Jun 10, 2005 10:10 pm
A PCV would be very Easy to Bling Up :lol:
PostPosted: Fri Jun 10, 2005 10:59 pm
Get the body anodised, paint the top.
Chris
Everything I like is either
Users browsing this forum: No registered users and 116 guests
