dash lights https://www.ausmini.com/forums/viewtopic.php?f=2&t=90529 |
Page 1 of 2 |
Author: | mooman10_0 [ Sun Sep 13, 2015 8:19 pm ] |
Post subject: | dash lights |
Hi everyone, playing with the lights today, I have reont lights, highbeam, but no dash lights. Oil, high beam ant alt lights all work, is just thelights on the dash at night which dont light up. Any idea what I should look for? Have turned park light things both ways to make sure it wasnt that. Cheers, Steve |
Author: | gtogreen1969 [ Sun Sep 13, 2015 8:21 pm ] |
Post subject: | Re: dash lights |
Have you tried bypassing the dimmer switch near your right knee |
Author: | winabbey [ Sun Sep 13, 2015 8:27 pm ] |
gtogreen1969 wrote: Have you tried bypassing the dimmer switch near your right knee Apologies for the slight diversion - what does the dimmer switch look like? What models what is fitted to? |
Author: | gtogreen1969 [ Sun Sep 13, 2015 8:34 pm ] |
winabbey wrote: gtogreen1969 wrote: Have you tried bypassing the dimmer switch near your right knee Apologies for the slight diversion - what does the dimmer switch look like? What models what is fitted to? Mine is a plain 1977 Leyland and has this under the lower parcel shelf in front of your right knee. http://www.ebay.ie/itm/Vintage-Lucas-Rh ... 41991fe9a2 |
Author: | mooman10_0 [ Sun Sep 13, 2015 8:35 pm ] |
I tried turning it, is it just a matter off joining the two wires? Cheers, Steve |
Author: | gtogreen1969 [ Sun Sep 13, 2015 8:46 pm ] |
I would check one wire has power then touch them together quickly to see if the lights come on. It should be ok to plug them together. There may be a double terminal to plug them both into at the back of the switch. You may need to get another one if going for a roadworthy as it was an ADR thing. |
Author: | mooman10_0 [ Sun Sep 13, 2015 8:47 pm ] |
thanks for that, I think I need to get me an electrical tester!!! |
Author: | gtogreen1969 [ Sun Sep 13, 2015 8:51 pm ] |
mooman10_0 wrote: thanks for that, I think I need to get me an electrical tester!!! For $20 you will get your money's worth out of one. |
Author: | mooman10_0 [ Sun Sep 13, 2015 8:53 pm ] |
just bought on ebay ![]() |
Author: | gtogreen1969 [ Sun Sep 13, 2015 9:03 pm ] |
mooman10_0 wrote: just bought on ebay ![]() I do a lot of online shopping. Just not worth the $15 in fuel to go to the nearest shopping centre. What one did you buy. Like this http://www.ebay.com.au/itm/LCD-Digital- ... 3f42e99ecd |
Author: | drjbeam [ Sun Sep 13, 2015 9:06 pm ] |
My 74 has one if dougs after dates From the mini king parts book now mini kingdom online Page 210 item 10 part number 13h9027 add a s at the end if second hand wanted |
Author: | gtogreen1969 [ Sun Sep 13, 2015 9:09 pm ] |
drjbeam wrote: My 74 has one if dougs after dates 1978 LS's have them as well |
Author: | Morris 1100 [ Sun Sep 13, 2015 9:15 pm ] |
I thought all Clubbies/Leyland Mini had them? |
Author: | drjbeam [ Sun Sep 13, 2015 9:31 pm ] |
And its in the owners manuals for both non pollution gear and before non pollution gear minis |
Author: | drjbeam [ Sun Sep 13, 2015 9:32 pm ] |
Morris 1100 wrote: I thought all Clubbies/Leyland Mini had them? Yeah they did |
