Speedometer repairs https://www.ausmini.com/forums/viewtopic.php?f=2&t=90534 |
Author: | drmini in aust [ Mon Sep 14, 2015 6:55 pm ] |
Post subject: | Speedometer repairs |
I had a 200KMH `Smiths' (aftermarket) speedo in my Mini. This one: http://minispares.com/product/Classic/G ... o%20search It has now done around 20,000KM. For the last year or so the speed indication has crept lower and lower at a given speed. However the odometer still reads correctly. Eventually I fitted a 140KMH Moke one instead. Today I took the 200KMH one to an instrument repairer (who shall remain nameless) for a repair quote. He tested it, its speed @ 60KMH was indicating 17KMH low. Then tested at 100KMH? it was much further out. His comment: " These speedos made since Smiths closed down are not well made, there is little or no lube held in the spindle bush, so they either wear bad (like mine has), or they seize up". Not worth fixing, he reckons. I had a 130MPH version of this same speedo, it worked just fine for nearly 30,000 MILES until I swapped it out for the 200KMH one. I know Danny_ has just seized his 200KMH one of the same type, so my question: how common is this? Is it worth just shelling out for another new one, and hoping for the best? Or can other places fix them so they last, at a reasonable price? |
Author: | timmy201 [ Mon Sep 14, 2015 7:46 pm ] |
Post subject: | Re: Speedometer repairs |
What TPM are the moke 140kph speedos out of interest? |
Author: | kiwiinwgtn [ Mon Sep 14, 2015 9:23 pm ] |
When I lived in Melbourne. I had a few things fixed by Howard Instruments. The good thing he is a mini guy. May be worth a call Kiwiinwgtn |
Author: | miniandmokeworld [ Mon Sep 14, 2015 9:39 pm ] |
Yes, they have had issues with the 200 KPH speedo's, inc voltage stab. WE have been fitting the late 140/160 KPH internals to the new speedos for reliability, steel internals instead of plastic. AB. |
Author: | drmini in aust [ Mon Sep 14, 2015 10:26 pm ] |
timmy201 wrote: What TPM are the moke 140kph speedos out of interest? The Cooper S 200KMH one is 800 turns/km. So is the 140KMH Moke one. Both suit a 3.44 diff and 10" wheels. There is also an 860turns/km Moke one, it's pretty close for a 3.64 diff and 10" wheels. That's what I put in Barney when we owned him. Sorry, I have no idea what year Mokes these KMH speedos are from, I'd say big wheel ones though. |
Author: | 9YaTaH [ Tue Sep 15, 2015 9:01 am ] |
drmini in aust wrote: I had a 200KMH `Smiths' (aftermarket) speedo in my Mini. This one: http://minispares.com/product/Classic/G ... o%20search It has now done around 20,000KM. For the last year or so the speed indication has crept lower and lower at a given speed. However the odometer still reads correctly. Eventually I fitted a 140KMH Moke one instead. Today I took the 200KMH one to an instrument repairer (who shall remain nameless) for a repair quote. He tested it, its speed @ 60KMH was indicating 17KMH low. Then tested at 100KMH? it was much further out. His comment: " These speedos made since Smiths closed down are not well made, there is little or no lube held in the spindle bush, so they either wear bad (like mine has), or they seize up". Not worth fixing, he reckons. I had a 130MPH version of this same speedo, it worked just fine for nearly 30,000 MILES until I swapped it out for the 200KMH one. I know Danny_ has just seized his 200KMH one of the same type, so my question: how common is this? Is it worth just shelling out for another new one, and hoping for the best? Or can other places fix them so they last, at a reasonable price? A sad state of affairs...feedback to the suppliers may get the "manufacturers" (word used advisedly!) to clean up their act or induce the suppliers to find another source ![]() |
Author: | cooper19613 [ Tue Sep 15, 2015 10:35 am ] |
Several of us Newcastle cars have had the same problem. Had a local instrument repairer replace the internals (supplied by us) but was still expensive-more than the cost of the speedo originally. Even more annoying was having to take mine back a couple of times as they calibrated it incorrectly. |
Author: | drmini in aust [ Tue Sep 15, 2015 10:39 am ] |
Looks like I'll just keep using the Moke one, and hang this sick puppy on the wall. It's only a club car now, so not worth spending a small fortune. Can Nb cars use a 200KMH speedo face? if so, it might have further use as decoration. ![]() |
