danny_ wrote:
I bought a GT40R as i could not find any GT40's, Does that mean i need to buy BPR5 plugs or can i still run BP5/6 plugs?
It has a brit parts electronic ignition installed.
I'm running a GT40R with a Powerspark module and a Black Box. It works OK. But I think they recommend a 3 ohm coil for both it and the Britparts one.
I have a new GT40 coil here if you want to swap.
You can use BPR5ES or 6ES plugs, your call.
[edit]
Taken from the mini forum.uk site,
re the Britparts one-
"I believe the main reason for these unit failing in a mini is the coil,
using either a ballast type or the electronic ignition type is a recipe for disaster. Ran one on my Elf for 12 months, swapped the engine(and the coil), the unit failed in minutes.
Use a a standard 12v coil".
My emphasis.
[edit 2]
from simonbbc.com site, re the Powerspark one-
To be used with a coil with resistance above 1.5 ohms only"
I have used GT40R coils on Pulsar electronic dizzies for years, but they used a Hitachi 1.5 ohm coil, and no ballast resistor.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
