It is currently Thu Jul 31, 2025 5:59 pm
 Post subject: Door Handle 65-71
PostPosted: Mon Oct 05, 2015 12:28 pm
Hi,
Does anybody know if this can be repaired? The key way has broken away and therefore the door cannot be locked
Or does anybody have one?
Its off the driver side of a morris 65-71
Jenk.
 Post subject: Re: Door Handle 65-71
PostPosted: Mon Oct 05, 2015 12:49 pm
They are pot metal, I don't think are weldable (and yes, I'm a welder).
You need to source a good s/h one, sorry!
PM to John Smidt, or TheMiniMan, on here.
PostPosted: Mon Oct 05, 2015 2:37 pm
you might have good luck with some JB weld, I've done a few things and they're standing up much better than I expected
PostPosted: Mon Oct 05, 2015 3:14 pm
OK Ill ask... What's JB weld??
Jenk.
PostPosted: Mon Oct 05, 2015 3:15 pm
Thanks Doc.
Jenk.
PostPosted: Mon Oct 05, 2015 3:26 pm
You could try one of the alloy brazing/soldering type of products. Durafix, muggyweld or alumiweld. They have a lower melting point than real welding, and will bond to alloys like zinc diecast and aluminum alloy.
I've found it quite hard to use though, you have to get the temperature just right or it all just runs off.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Oct 05, 2015 4:53 pm
this sort of stuff - it's runny when mixed and then sets hard. Hard enough to drill, file etc.
http://www.supercheapauto.com.au/online ... mendations
PostPosted: Mon Oct 05, 2015 5:18 pm
JB weld is a surprisingly good and strong product as long as you can get it to stay where you want it to before it sets
PostPosted: Wed Oct 07, 2015 1:54 pm
I assume that it is off a wind up window door. If so Flynns Wrecking Yard in Cooma have a number of them still on cars. Wayne is the owner of the yard.
PostPosted: Wed Oct 07, 2015 4:05 pm
Thanks Kath... much appreciated.
Jenk.
PostPosted: Thu Oct 08, 2015 6:08 am
It would be easy and strong enough to just used DAVCON.
"Let us remove your "SHORTS"
PostPosted: Thu Oct 08, 2015 8:49 am
Or Devcon
Users browsing this forum: No registered users and 72 guests
