It is currently Wed Jul 23, 2025 1:31 am
PostPosted: Wed Sep 30, 2015 12:39 am
It seems as though every time I have an issue with my car I find a very shonky fix from the PO.
Just thought I would share the latest one I have found - electrical tape wrapped around the gear lever internals.
PostPosted: Wed Sep 30, 2015 2:11 am
Ah, but did it work (temporarily).
My 850 had the battery cable run from the battery inside the car and then out under the gear lever boot to the starter button. When I gave it a tug to pull it through from the boot, only half of the cable came out. The two halves were twisted together and covered with electrical tape :shock:
Everything I have looked at to adjust has been dodgy by the PO :evil:
Buyer beware !
PostPosted: Wed Sep 30, 2015 8:15 am
i guess sometimes you need a temporary fix and then you end up just leaving it because it works? i have done that a few times but have always gone and fixed it all up afterwards having said that i found quite a bit with my mini (red one) that i would have changed / done differently to the previous owner. i guess its all down to the person that owns it at the time because he might have thought that it was ok to leave it like that because it worked? or maybe he had to fix it to sell it you never know.
PostPosted: Wed Sep 30, 2015 10:17 am
An informal/dodgy "clearing house" (run by a middle aged couple from their house) working for a large Nth Shore dealer sold me a Mini (private sale) where the wheel cylinders had been sleeved with shim brass...quite dangerous.
unbelievable when you consider that replacement units were cheap as chips at the time... :evil:
PostPosted: Wed Sep 30, 2015 10:58 am
i agree with dodgy repairs are not cool but sometimes i guess people look past them and say it will be fine. like the red mini i bought the guy went to all the effort in doing what hi did to the car but still left the old gear stick in that had be cut and rewedded to make is smaller.it snapped in half going down the free after shifting in to fourth.
PostPosted: Wed Sep 30, 2015 1:14 pm
My favourite was the cardboard glued over the top of a huge rust hole.
PostPosted: Wed Sep 30, 2015 1:18 pm
So that's how you fix the gear lever rattle!
PostPosted: Wed Sep 30, 2015 5:08 pm
Fiberglass repairs to rusty floors! I hate em!
PostPosted: Wed Sep 30, 2015 5:33 pm
I suppose I should be thankful that the cardboard wasn't glued down very well. Fiberglass would be a bit harder to lift.
PostPosted: Wed Sep 30, 2015 6:03 pm
Easy to replace though. Or upgrade to waxed cardboard protection.
PostPosted: Thu Oct 01, 2015 2:07 am
Waxed cardboard :wink: genius Mick.
Won't rot/fall apart when wet. Remind me not to buy a car off you :D
PostPosted: Thu Oct 01, 2015 5:34 am
Previous owner of my mini worked on the idea that stone guard hides all sins, if in doubt spray another coat! Inside the boot looks dodgy? Spray some stone guard!
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Thu Oct 01, 2015 9:19 am
Only the best!
PostPosted: Thu Oct 01, 2015 10:01 am
I had a mini van that had been entirely re-wired in transparent speaker cable - it was a nightmare to troubleshoot!
I found a christmas card used as a gasket once.
How about slices of Coke can to pack out main and big-end bearings?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Oct 01, 2015 10:04 am
well, they'll never be NLA....
Users browsing this forum: Bing [Bot] and 81 guests
