Thermostat Housing Question https://www.ausmini.com/forums/viewtopic.php?f=2&t=90711 |
Author: | jpodge [ Sun Oct 04, 2015 6:13 pm ] |
Post subject: | Thermostat Housing Question |
I've just come across a new alloy radiator for my 76 clubman however the clubman is fitted with a rear facing thermostat housing and the radiator has a forward facing top hose. Is the bolt pattern the same to just swap the rear facing housing for a front facing housing? Probably a stupid question but just want to be sure. Cheers Joe |
Author: | drmini in aust [ Sun Oct 04, 2015 9:13 pm ] |
Post subject: | Re: Thermostat Housing Question |
I have done this to a friend's car (with a 1098 motor). The bolt pattern is close. I had to mod a top rad bracket to fit. There is a proper thermo housing for this though, also one for a 1275, with the rad hose to the rear. You can find them on eBay. |
Author: | Mick [ Sun Oct 04, 2015 9:34 pm ] |
I thought the answer was a straight up yes Kev? I didn't think the bolt pattern changed for any head?. |
Author: | drmini in aust [ Sun Oct 04, 2015 9:37 pm ] |
If you measure the 3 bolt spacing on the head, it is an isosceles triangle, not quite an equilateral one. But it will fit due to the hole clearance. That's why the gasket only fits properly, 2 ways. Note you can't do this with a 1275, the different bolt pattern angle points the hose at the head. |
Author: | Morris 1100 [ Sun Oct 04, 2015 9:43 pm ] |
jpodge wrote: I've just come across a new alloy radiator for my 76 clubman however the clubman is fitted with a rear facing thermostat housing and the radiator has a forward facing top hose. Is the bolt pattern the same to just swap the rear facing housing for a front facing housing? Probably a stupid question but just want to be sure. Cheers Joe Yes, you can fit the earlier thermostat housing to match the new radiator. |
Author: | Mick [ Sun Oct 04, 2015 10:18 pm ] |
Oh I see what you mean Kev, you mean to rotate the thermostat housing you already have with a little elongation of the hole. cheers |
Author: | drmini in aust [ Sun Oct 04, 2015 10:24 pm ] |
Mick wrote: Oh I see what you mean Kev, you mean to rotate the thermostat housing you already have with a little elongation of the hole. cheers No need to elongate the holes, they have a bit of clearance. But stick an 8.5mm drill through them to clean the crud out. |
Author: | simon k [ Mon Oct 05, 2015 9:34 am ] |
Morris 1100 wrote: jpodge wrote: I've just come across a new alloy radiator for my 76 clubman however the clubman is fitted with a rear facing thermostat housing and the radiator has a forward facing top hose. Is the bolt pattern the same to just swap the rear facing housing for a front facing housing? Probably a stupid question but just want to be sure. Cheers Joe Yes, you can fit the earlier thermostat housing to match the new radiator. ditto for emphasis.... he wasn't asking if he could rotate it, he was asking if he could swap it ![]() |
Author: | drmini in aust [ Mon Oct 05, 2015 10:00 am ] |
simon k wrote: Morris 1100 wrote: jpodge wrote: I've just come across a new alloy radiator for my 76 clubman however the clubman is fitted with a rear facing thermostat housing and the radiator has a forward facing top hose. Is the bolt pattern the same to just swap the rear facing housing for a front facing housing? Probably a stupid question but just want to be sure. Cheers Joe Yes, you can fit the earlier thermostat housing to match the new radiator. ditto for emphasis.... he wasn't asking if he could rotate it, he was asking if he could swap it ![]() Sorry, I was having a senior moment..! ![]() |
Author: | jpodge [ Mon Oct 05, 2015 2:24 pm ] |
Thanks guys! |
Author: | simon k [ Mon Oct 05, 2015 2:34 pm ] |
drmini in aust wrote: Sorry, I was having a senior moment..! ![]() lol... not another one Kev! ![]() don't worry old fella, we're watching out for you |
Author: | TheMiniMan [ Mon Oct 05, 2015 5:22 pm ] |
we have the new (early) thermostat housings , hoses & gaskets etc here if you need them i`m at the shop all day & night today/night building gearboxes so if you need a housing &/or gaskets &/or anything else then i`m here till late tonight & tomorow & the next day & the next day but probably going surfing friday ![]() Matt 0407 135 656 Murarrie |
