Door Handle 65-71
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90718
Author:  Jenk [ Mon Oct 05, 2015 12:28 pm ]
Post subject:  Door Handle 65-71
Hi,
Does anybody know if this can be repaired? The key way has broken away and therefore the door cannot be locked
Or does anybody have one?
Its off the driver side of a morris 65-71
Author:  drmini in aust [ Mon Oct 05, 2015 12:49 pm ]
Post subject:  Re: Door Handle 65-71
They are pot metal, I don't think are weldable (and yes, I'm a welder).
You need to source a good s/h one, sorry!
PM to John Smidt, or TheMiniMan, on here.
Author:  simon k [ Mon Oct 05, 2015 2:37 pm ]
you might have good luck with some JB weld, I've done a few things and they're standing up much better than I expected
Author:  Jenk [ Mon Oct 05, 2015 3:14 pm ]
OK Ill ask... What's JB weld??
Author:  Jenk [ Mon Oct 05, 2015 3:15 pm ]
Thanks Doc.
Author:  Timbo [ Mon Oct 05, 2015 3:26 pm ]
You could try one of the alloy brazing/soldering type of products. Durafix, muggyweld or alumiweld. They have a lower melting point than real welding, and will bond to alloys like zinc diecast and aluminum alloy.
I've found it quite hard to use though, you have to get the temperature just right or it all just runs off.
Author:  simon k [ Mon Oct 05, 2015 4:53 pm ]
this sort of stuff - it's runny when mixed and then sets hard. Hard enough to drill, file etc.
http://www.supercheapauto.com.au/online ... mendations
Author:  guna mk1 [ Mon Oct 05, 2015 5:18 pm ]
JB weld is a surprisingly good and strong product as long as you can get it to stay where you want it to before it sets
Author:  kath20 [ Wed Oct 07, 2015 1:54 pm ]
I assume that it is off a wind up window door. If so Flynns Wrecking Yard in Cooma have a number of them still on cars. Wayne is the owner of the yard.
Author:  Jenk [ Wed Oct 07, 2015 4:05 pm ]
Thanks Kath... much appreciated.
Author:  Convertible Mini [ Thu Oct 08, 2015 6:08 am ]
It would be easy and strong enough to just used DAVCON.
Author:  gtogreen1969 [ Thu Oct 08, 2015 8:49 am ]
Or Devcon
