Direct gear change shaft
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90741
Author:  Phil 850 [ Wed Oct 07, 2015 5:14 pm ]
Post subject:  Direct gear change shaft
I have the diff housing for an 850 direct gear change and I have removed the remote control shaft.
Is there a spring behind the nylon seat inside the shaft head below, and how do I get the seat out :|
Author:  drmini in aust [ Wed Oct 07, 2015 5:50 pm ]
Post subject:  Re: Direct gear change shaft
Yes there is a spring,
screw a small tap or ezy out or a big self tapper into the cup. Then pull it out.
Author:  Phil 850 [ Wed Oct 07, 2015 6:14 pm ]
Thanks Kev.
I bent a bit of stiff wire and shoved it in and pulled it out :D
