It is currently Sat Jul 26, 2025 4:09 pm
PostPosted: Sat Oct 10, 2015 12:06 pm
Ladies and gents,
I'm trying to track down the "good" SKF thrust bearing.
As I understand these have been NLA for a while.
Does anyone have a source or reliable alternative?
Will
PostPosted: Sat Oct 10, 2015 5:33 pm
Will,
I think the flat ones both SKF and Timken are pretty much gone.
[edit] Karcraft has the flat one listed in my 06/15 catalog, p/no GRB238#. Not sure if in stock.
I have been using the later design RHP one since 2007, with an orange dot plate.
It is still working good. Car has done over 16,000 miles with it in.
But, note:
1. the clutch height was set properly, the diaphragm spring is flat when assembled.
2. I don't hold the clutch in waiting for the lights.
3. I don't use the clutch pedal for a footrest. :)
If buying late type release bearings, try and get UK made, or at least `made in EEC'.
Or, this one- http://www.minisplus.com.au/classic-min ... ing-7w-5-8
I'd stay away from noname ones.
[edit] PM sent.
Users browsing this forum: slacko and 91 guests
