It is currently Mon Jul 21, 2025 3:49 am
PostPosted: Mon Oct 12, 2015 2:17 pm
Hi Folks,
Just wondering if anyone north of Brisbane has a flywheel puller I could borrow for a night? Who would have thought the thing would be on so tight... :wink:
There's a six pack in it for anyone kind enough!
Let me know if this should be posted elsewhere.
Pat.
PostPosted: Mon Oct 12, 2015 5:32 pm
What suburb are you in?
PostPosted: Mon Oct 12, 2015 7:14 pm
Hey Ken,
I'm in Albany Creek.
I don't actually need to pull it off, but I bought a clutch kit needing a new throwout bearing and a couple of other bits so I figured I may as well pull it all off.
But a fella from Rovertech in Brendale reckons don't pull it off unless I really need to as everyone knows there's a fair chance it could be an absolute mongrel to get off even with a puller.
Not sure what to do now.
PostPosted: Mon Oct 12, 2015 7:18 pm
I'm in Wilston and you can borrow mine if you can't find one closer.
Early in the morning or late evening pick up because I'm working all hours at the moment.
M
PostPosted: Mon Oct 12, 2015 7:22 pm
They (all Oz pre-Verto ones) come off pretty easily usually, I've only seen 1 over the years my puller wouldn't get, and that's because it had spun 90deg and welded to the crank when the motor broke a rod and things screamed to a halt. Got oxy out. :)
As a Mini owner, it's something that gets a bit of use- so why not make one for the future? I have put details in the how-to forum.
PostPosted: Mon Oct 12, 2015 7:34 pm
Cheers Mokesta, I'll PM you.
Yeah cheers doc, I've had a squiz at your how to, and I think I'll definitely be making one in the future. Fortunately Dad's got a lathe out at his workshop, it's just a struggle to get time out there.
I'll give it a go for sure, I'd feel a bit defeated otherwise!
PostPosted: Mon Oct 12, 2015 8:36 pm
Mine had to be Oxyed off a few years ago... broke 2 pullers
