It is currently Mon Jul 21, 2025 6:32 pm
 Post subject: Electric Die Grinders
PostPosted: Mon Nov 09, 2015 6:29 pm
Who's got one,
What type.
What do you think of it.
Do they compare well with Air powered ones.
I don't have room for a Compressor in my jam packed garage.
Advice please.
PostPosted: Mon Nov 09, 2015 7:08 pm
GR uses an electric die grinder for all head work, and it gets a big workout.
At my last job we had a Makita one, it was good with carbide burrs but speed was only 7000 rpm.
be aware there are both 6mm and 6.35mm (1/4") standards for the collets.
You can fit & use 6mm burrs & stones in the 1/4" chuck, but not the reverse.
(edit) I like my Ingersoll Rand 22,000rpm air one. 1/4 HP. :P
Last edited by drmini in aust on Mon Nov 09, 2015 8:20 pm, edited 1 time in total.
PostPosted: Mon Nov 09, 2015 7:28 pm
Extend the Garage :!: :idea:
PostPosted: Mon Nov 09, 2015 7:41 pm
My preferred option but the Rumpus Room is behind the garage.
Now I don't mind working on the mini in the rumpus room BUT :|
Thanks Kev
1/4" collet is the way to go then.
PostPosted: Tue Nov 10, 2015 3:15 pm
Phil 850 wrote:
Who's got one,
What type.
Advice please.
I've got a Makita GD0602. Seems to be OK as never used an air grinder. 25000RPM. Don't recommend using cheap stones and extension cable bendy thing. It kinked while I was using it. Yeah...not good. :shock:
PostPosted: Tue Nov 10, 2015 7:23 pm
I have a Makita one as well. Rather use that than the air one, compressors don't have a very good duty cycle.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Nov 10, 2015 8:08 pm
What model Makita Scoop ?
Users browsing this forum: Bing [Bot], timmy201 and 83 guests
