Brake certification.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90830
Author:  Hobson [ Tue Oct 20, 2015 10:18 am ]
Post subject:  Brake certification.
Has anyone in the past been asked by the blue slip man to get brake modifications certified. I am happy to do it and think it is a very good idea, what are the forms and fees associated, does anyone know? apart from the usual blue slip cost, yada yada yada.
I have the Brake assessment manual printed out and will have a read through, has anyone been through this before?
Author:  timmy201 [ Tue Oct 20, 2015 10:40 am ]
Post subject:  Re: Brake certification.
The RMS VSI06 on page 8 and 9 details the modifications that can be done with and without certification. As far as I can tell, as long as the parts used are in the same configuration as an equivalent model (eg. Cooper S discs on an 850) it should be OK without certification.
http://www.rms.nsw.gov.au/documents/roa ... ations.pdf
Author:  Hobson [ Tue Oct 20, 2015 10:47 am ]
I did read that, but seeing as I am on vented 8.4's from mini sport uk, a 78 Leland s would work with with that extract seeing as the 1275 GT's came with 8.4's. But does the disks being vented throw a spanner in the works? I will be talking to the Eng later today to go through a few things, I will make sure to keep all the documentation for those wishing to do it in the future.
Author:  simon k [ Wed Oct 21, 2015 3:16 pm ]
yes, according to the above, they were never factory fitment in that configuration.
But they're also aftermarket alloy calipers with a different type of drive flange aren't they?
Or they might be from a Metro, which should be easier, but still needs checking according to the example above
(VT to LC)
Author:  Hobson [ Tue Nov 10, 2015 9:40 am ]
Engineer approved, picked up a weighbridge cert yesterday. blue slip next step, Should be able to help out if anyone needs a "similar car" certification in future.
