It is currently Sun Aug 17, 2025 1:51 pm
PostPosted: Mon Oct 26, 2015 9:03 pm
Good evening
Does anyone have the formula to work out speed by revs?
I'm trying to work out the speed of 5800 and 6000rpm on 10inch wheel and a 3.44 diff.
Thanks
PostPosted: Mon Oct 26, 2015 9:10 pm
This one says 99mph at 6000rpm in forth gear
http://www.guess-works.com/Tech/ratio.htm
PostPosted: Mon Oct 26, 2015 9:13 pm
154.2 and 159.5 respectively...
what you need to do is calculate the rolling circumference of the tyre, then because 4th gear is 1:1 you can multiply that by the diff ratio. I have a spreadsheet that JC shared a few years ago that's very handy
PM me an email address and I'll send it
PostPosted: Mon Oct 26, 2015 9:32 pm
Thanks guys.
Simon pm'd
PostPosted: Mon Oct 26, 2015 9:43 pm
16.4 mph per thousand revs... fine tune for actual wheel rolling radius...
Cheers, Ian
Users browsing this forum: Bing [Bot] and 369 guests
