Removing pot joint inner from driveshaft
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90856
Author:  drmini in aust [ Thu Oct 22, 2015 9:34 pm ]
Post subject:  Removing pot joint inner from driveshaft
Hey guys, I'm not a rodchange Clubby person (too old) so bear with me here.
I need to remove the pot joint inner spider and cage from 2 shafts so I can fit them into 2 new pot joints.
Is there an easy way (eg hit with BFH like a CV), or do I need to make a puller as shown in the Leyland book?
Author:  awdmoke [ Thu Oct 22, 2015 10:58 pm ]
Post subject:  Re: Removing pot joint inner from driveshaft
I've never needed any real force.
Just remove the circlip and they slide apart.
Author:  mini_mad_matt [ Fri Oct 23, 2015 12:40 am ]
How do you remove the circlip when it is on the inside?
Just give the inner spider a hit with a soft drift. They normally come off pretty easily
Author:  drmini in aust [ Sun Oct 25, 2015 10:39 am ]
Thanks guys, I gave them a tap with my BIG lumpa brass and they slid off.
Easier than expected. :)
Author:  michaelb [ Mon Oct 26, 2015 9:32 pm ]
Same as CV joints. They either come off easily with a big hammer or won't budge until destroyed by the same big hammer. ??
