Hi
Have noticed low oil pressure when engine has warmed up
Drops from 90psi when cold to 40psi when hot & 20psi at idle
Have began to strip motor & noticed that the oil pump gasket appears to be seeping oil thru the small sealing area between the HP outlet & the bolt hole. I can see oil has been collecting in the cavity next to the bolt hole. Also the paper material appears to be soaked in oil.
There is no sign of oil on the outside of the pump.
Has anyone else had this problem?
How much of a leak will it take to drop the oil pressure tom 40psi?
Note that this has just happened. The engine has been built & been running for 5 years reliably
https://www.flickr.com/photos/stefir/22 ... ed-public/
