Mini front subframe questions.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90915
Author:  Budgiedagreat [ Thu Oct 29, 2015 3:59 pm ]
Post subject:  Mini front subframe questions.
So I have a 1978 mini clubman but have a dry pre 1976 front subframe can I still use this on my clubman or do I have to modify the tower bolts.
The tower bolt is different on dry 1976 onwards than dry pre 1976. Image
Author:  Morris 1100 [ Thu Oct 29, 2015 4:52 pm ]
Post subject:  Re: Mini front subframe questions.
Australian Minis never changed to the single tower bolt mount.
Author:  drmini in aust [ Thu Oct 29, 2015 4:52 pm ]
Don't believe what you see on the web.
Not in Australia it's not.
All our Clubby subframes were 2 bolt, right to the end.
The Poms went to the single bolt mount setup so they could rubber mount the subframe for crap handling.
Author:  Budgiedagreat [ Thu Oct 29, 2015 6:07 pm ]
Awesome!! Thanks guys body's at the shop getting sprayed so couldn't look at where the subframe fixes to the body. So this helps
Author:  womble99 [ Fri Oct 30, 2015 10:54 am ]
How come you see some sub frames with studs instead of bolts?
Author:  drmini in aust [ Fri Oct 30, 2015 11:10 am ]
Most hydro ones had bolts & I think most dry had studs but not all.
