It is currently Fri Jul 18, 2025 9:41 pm
 Post subject: Changing Diff Ratio
PostPosted: Fri Oct 30, 2015 5:47 pm
Hi Guys
I have a rubber Yoke style output shaft not the hardy-spicer type and i was wondering to change the diff ratio, can i use the crown and pinion from a hardy-spicer diff and install it on mine. So in other words is the crown and pinion compatible and i can still use my yoke set-up.
 Post subject: Re: Changing Diff Ratio
PostPosted: Fri Oct 30, 2015 5:48 pm
yes
PostPosted: Fri Oct 30, 2015 8:17 pm
Not sure what ratio you're thinking of, but I converted mine many years ago to 3.44 in a fully synchro box with 1098cc warmish motor. Very nice and quiet cruiser at 100kph.
PostPosted: Fri Oct 30, 2015 8:36 pm
Thanks guys
