It is currently Sat Jul 26, 2025 6:13 pm
PostPosted: Mon Nov 02, 2015 4:01 pm
Hi
My door cards tend to bang/rattle and I was wondering if someone could advise how to fit them properly.
I found some clips on mini kingdom online part no HYA1860 and was curious if these are what I needed.
Some pictures would be great
Thanks all
PostPosted: Mon Nov 02, 2015 4:27 pm
Tomtax wrote:
Hi
Thanks all
http://www.classicmotoring.net.au/cmos/ ... ts_id=1119
PostPosted: Mon Nov 02, 2015 5:02 pm
Hi David
I think these clips are for front door cards. It seems the rear cards just sit in place with no clips
PostPosted: Mon Nov 02, 2015 5:21 pm
Found this link problem solved. My cards are too small hence my problem
http://optauto.easyspaceshops.com/Fitti ... ds-MK1-MK2
PostPosted: Mon Nov 02, 2015 8:09 pm
My 66 deluxe and 67 Cooper S had strips of under felt made into a loop and glued to the back of the board. This appears to provide some outward pressure to the liner and stops it rattling as well.
Anyone else seen this?
Rod
PostPosted: Tue Nov 03, 2015 4:54 am
Tomtax wrote:
Hi David
That is so, Tom, but I have never heard them called rear door cards. John Smit's Mini Kingdom catalogue of the late 90's calls them rear quarter trim panels. That makes much more sense to me. The clips you introduced into the discussion are for the door cards (driver and passenger).
