It is currently Thu Aug 21, 2025 5:19 pm
 Post subject: 65DM4 distributor
PostPosted: Wed Nov 04, 2015 7:31 pm
G'day everyone, is any running with a 65DM4 distributor? Just want to confirm the coil resistance. I currently have a 3 ohm coil (GT40T) and I understand that the 65DM4 should be less than 1.5. This could explain the issues I am having with the car stumbling.
 Post subject: Re: 65DM4 distributor
PostPosted: Wed Nov 04, 2015 7:38 pm
Hi Yes should be 1 ohm or less. I run this dizzy in my 1360 / RE13 cam.
The other thing is the curve in these dizzys are way off if the car is modified.
I sent mine to Graham Russell who re-graphed it. This made a substantial difference to the running of the car.
Its worth swapping coils to see if this the difference.
Thanks
Bernard
PostPosted: Wed Nov 04, 2015 7:41 pm
Thanks Bernard, what would be the implications/ effects of running a 3 ohm coil on a distributor requiring less than 1. I am not really educated in the whole residence concept
PostPosted: Wed Nov 04, 2015 8:01 pm
The first thing is you will eventually fry the module on the side of the dizzy.
I am not sure but you may not be getting full spark, is the spark a nice blue colour or a yellow (weak spark)
The modules are not cheap so I would get the correct coil. I have blown one. they can be hard to get as well these days
PostPosted: Wed Nov 04, 2015 8:16 pm
The spark is a nice blue colour at idle but as I have worked out the car could be falling apart and still tune at idle. It's struggling under load. Recommendations for a correct coil?
Users browsing this forum: No registered users and 334 guests
