It is currently Mon Aug 11, 2025 12:06 am
 Post subject: Rear brake locked on.
PostPosted: Sat Dec 05, 2015 5:54 am
After 3 years on stands, with handbrake on, the left rear brake on my 74 clubman is now stuck solid. The car is due to be picked up today on a trailer to go to a knew home.
I can't turn the adjuster, the handbrake cable isn't seized, I can move the actuator arm part that the cable connects to. I'm assuming the something has seized in the internal handbrake mechanism.
Any suggestions for how I might best approach this?
PostPosted: Sat Dec 05, 2015 6:18 am
Try to get the brake drum off to see what is going on in there.
PostPosted: Sat Dec 05, 2015 6:35 am
Take hammer and tap around the outside of the drum.
It sounds like the shoe has bonded itself to the drum.
If there are removal holes in the drum, you could use them to apply some force to help push the drum off.
PostPosted: Sat Dec 05, 2015 6:45 am
Yep carefully tap all around with a BFH. Remove the two countersunks and try to move the drum back and forth whilst pulling off (well trying too!! :-)
PS in extreme cases you may need a large puller to "coax" the drum off
PostPosted: Sat Dec 05, 2015 7:42 am
Get the oxy out. Heat will fix it or xxxxx it.
PostPosted: Sat Dec 05, 2015 7:47 am
Unless it's stood for a zillion years, a tap around should do it.
If not, I'd spray the adjuster with WD40 or penetrene, then warm it up with a hot air gun.
I once needed the angle grinder to cut drums off Josh's old Moke that came off a farm in Kingaroy Qld. They were seized solid.
Users browsing this forum: Bing [Bot] and 116 guests
