Dry subframe mounting studs. https://www.ausmini.com/forums/viewtopic.php?f=2&t=91286 |
Author: | Mick [ Mon Dec 14, 2015 10:15 pm ] |
Post subject: | Dry subframe mounting studs. |
Does anyone have a photo of the studs which the dry subframe uses to bolt to the engine bay cross member? I seem to remember they are 9/16" one end and 1/2" the other with a taper on the shank. I am more used to hydro frames and all my bolts are off being plated ![]() |
Author: | snurkdog [ Tue Dec 15, 2015 7:22 am ] |
Post subject: | Re: Dry subframe mounting studs. |
i think more like 3/8"x5/16"either end |
Author: | DavidE [ Tue Dec 15, 2015 7:53 am ] |
snurkdog wrote: i think more like 3/8"x5/16"either end Yes, and with a reduced shank rather than a tapered one. |
Author: | Mick [ Tue Dec 15, 2015 10:48 am ] |
Ah yes. sorry I stated AF instead of thread size... Thanks very much. For the moment I will use a pair of gearbox studs to line it in place. They're 3/8 UNF to 3/8 UNC but will do to get the thing lined up until I get the bolts back. |
Author: | DavidE [ Tue Dec 15, 2015 1:53 pm ] |
Mick wrote: Ah yes. sorry I stated AF instead of thread size... Thanks very much. For the moment I will use a pair of gearbox studs to line it in place. They're 3/8 UNF to 3/8 UNC but will do to get the thing lined up until I get the bolts back. I'm not all all sure how that will go for you. The holes in the bulkhead cross-member will be expecting a 5/16" stud, won't they? Cheers |
Author: | Mick [ Tue Dec 15, 2015 1:55 pm ] |
They accept the 3/8 studs and I think they would accept more! A lot of leeway for chassis alignment I suspect. They wouldn't be built this way these days... |
Author: | drmini in aust [ Tue Dec 15, 2015 5:45 pm ] |
Mick wrote: They accept the 3/8 studs and I think they would accept more! A lot of leeway for chassis alignment I suspect. They wouldn't be built this way these days... Even with all that leeway, when I swapped to a GT subby in mine I had to chase one of the subby threads in situ. I have a 5/16 UNF tap with 200mm of square bar welded to it. ![]() |
