It is currently Sun Aug 03, 2025 2:39 am
PostPosted: Mon Jul 18, 2005 10:29 am
Hmmm I've just realised that i now need to use the 1275 radiator bracket and steady bracket.....
I've got a steady brackey, but dont remember seeing one installed...
Can you big-block boys and girls take some pics for me ?
inquiring minds need to know.....
J
PostPosted: Mon Jul 18, 2005 10:33 am
No pics sorry-
It goes onto the head first, then the thermo housing.
Not much room for it at front end of head. PITA to fit compared to the smallbore one. :x
PostPosted: Mon Jul 18, 2005 10:40 am
We used the standard steady and made up custom brackets front and rear - [sitting on a 940 head]
The front steady needs to extend further rearwards to clear the extra meat at the back of the big bore head. So the steady arm needs to be shorter to fit onto a standard rear bracket or you move the rear bracket mount hole backwards.
Hope it helps
Dat
PostPosted: Mon Jul 18, 2005 1:28 pm
I used the factory bracket on the car frame, but made up a bracket on the engine side, and used a standard steady bar. But my radiators different to most, apparently. Later clubbys had a different top hose arrangement.
Is yours later clubby/roundy/?
www.crazybitchracing.com
PostPosted: Mon Jul 18, 2005 1:36 pm
ROundy with 998 engine, Minispares 4-core and a 12G1361 head... (940)
hmmmmm
J
PostPosted: Mon Jul 18, 2005 1:43 pm
The difference is the top hose pointing backwards instead of to the front as the later clubbie's had the air pump attached to the thermostat housing.
PostPosted: Mon Jul 18, 2005 1:50 pm
air pump? huh? I dont remember seeing any air pump...
oooh the emission control air pump.. umm that went long time ago, but yeah, there are a couple of holes in the thermostat housing that would have been for that. I wondered what they were for :roll:
PostPosted: Mon Jul 18, 2005 1:52 pm
Yep... it's more common to see a Mini with one taken off, than one with it on. I've seen like 2 Mini's ever with the air pump. :lol:
