It is currently Sun Jul 20, 2025 11:57 am
 Post subject: Door hinge hardware
PostPosted: Sat Jan 09, 2016 10:01 pm
Just wondering if anyone sells a kit with all the studs, bolts, nuts and washers for original door hinges. I see kits for the reproduction/aftermarket aluminium(?) hinges that use metric fasteners but not for original ones. Failing that does anyone know what size the thread/pitch is on the originals so i can buy new fasteners? Unfortunately i lost them all after i stripped them down for a rebush. No doubt i will find the bag they were all in once i buy new ones
 Post subject: Re: Door hinge hardware
PostPosted: Sun Jan 10, 2016 6:09 am
The threads are 1/4 unf
PostPosted: Sun Jan 10, 2016 6:16 am
Don't forget that you need tapered washers and large penny washers for the upper hinges. Apart from the single bolt, you need two studs and a single rounded cheese head style screw for the fastening at the leading edge of each door mounting point.
PostPosted: Sun Jan 10, 2016 6:52 am
I made new studs from 1/4" UNF hex head setscrews [grade 5].
OT but related-
Boot hinges are fragile (they are zinc? not cast iron). They strip easy, the maker should have used UNC threads in them not UNF as they are so soft.
I fixed mine by tapping them 5/16" UNC, then turning 5/16 UNC Grade 5 bolts down to become 5/16 UNC x 1/4 UNF studs.
Last edited by drmini in aust on Sun Jan 10, 2016 9:52 am, edited 1 time in total.
PostPosted: Sun Jan 10, 2016 7:01 am
Make sure you use hi tensile studs.
"Let us remove your "SHORTS"
PostPosted: Sun Jan 10, 2016 8:03 am
The kits from "those UK suppliers" are good but chuck the studs they supply and fit HT made up ones. I think their bolts are Chinese cheese steel.
PostPosted: Sun Jan 10, 2016 8:51 am
Thanks guys. My mini didn't have the tapered washers but will make some up using the top hinges as a guide with studs fitted to get the angle right. The boot hinges are in excellent condition so i think i may leave them as is rather than mess with them. Just want to get the door hinges sorted so i can fit up everything and get it sorted and make sure everything fits right before i strip down and prep for paint
PostPosted: Sun Jan 10, 2016 9:54 am
Don't overtighten the boot hinges- the studs near the ends have very little thread length and strip out real easy.
PostPosted: Sun Jan 10, 2016 10:56 am
Will do. Thanks again
PostPosted: Sun Jan 10, 2016 11:36 am
The door hinge kits you buy with the studs/bolts are incorrect. They are a metric thread and are for the alloy hinges, not for the old cast steel type we have on our cars.
PostPosted: Sun Jan 10, 2016 12:02 pm
Oz ones are all grey cast iron.
This was obvious when my son had a head-on in his Clubby, and the doors fell onto the road. Burstproof locks? haha.
PostPosted: Sun Jan 10, 2016 12:33 pm
Must have been something wrong with the door handles then.
When I rolled my mini it broke the hinges, but door held on by the burst-proof handle though.
PostPosted: Sun Jan 10, 2016 12:37 pm
And yet the cast iron hinge passed the same ADR test as the locks.
There is no requirement for burstproof at all. (the word isn't in the ADR)
The door has to withstand a certain amount of side loading.
PostPosted: Sun Jan 10, 2016 2:54 pm
Remember: Those alloy hinges were made for the much lighter sliding window doors and not those big heavy wind ups that we have.
