how do I post a picture? https://www.ausmini.com/forums/viewtopic.php?f=2&t=9176 |
Author: | David [ Mon Jul 18, 2005 5:32 pm ] |
Post subject: | how do I post a picture? |
Hello, Can someone tell me how I post a picture on here? Thanks Dave |
Author: | Dylans Clubby [ Mon Jul 18, 2005 6:45 pm ] |
surprised no-one has responded to this yet! i bet someone is doing this at the same time as me... to post a pic, you need to: 1. host the pic(s) you want to post. a good place to do this is http://www.photobucket.com. its easy and quick. 2. after you ahve the pic hosted, you need its link. the actual pics link, not the link of the page it is on. photobucket gives you the link under the pic on its site. 3. copy the link and paste it in here hwere you type. then, there is a button up the top of the text box that says "Img", highlight the link then press this button. 4. if you want to type anything else, make sure it is outside the image tags. they look like (the first is open tag, the second is close. you need the first one at the start, and the last one at the end. i know that sounds obvious, but still...) 5. press "preview" to make sure it worked, then press "submit if it has! if it hasnt, revise the steps, check your link, make sure you have closed the tags... that should sort you out! |
Author: | David [ Mon Jul 18, 2005 6:48 pm ] |
cheers mate I will give this a go. Dave |
Author: | J_A_M [ Mon Jul 18, 2005 10:14 pm ] |
Isn't there a sticky for this?? There should be if there isn't!!! |
Author: | Harley [ Mon Jul 18, 2005 10:33 pm ] |
It's in rules, stickys and announcements. |
Author: | J_A_M [ Mon Jul 18, 2005 10:37 pm ] |
should add FAQ's to that forum title. |
Author: | WhoDat [ Mon Jul 18, 2005 11:48 pm ] |
If you get stuck David, have a look in here ... http://www.ausmini.com/forums/viewtopic.php?p=86794 It tells you all you need to know about getting your picture up on the forums. Cheers Dat |
Author: | aussie [ Tue Jul 19, 2005 12:38 am ] |
will knows how to, ask him ![]() |
Author: | willy [ Tue Jul 19, 2005 12:39 am ] |
Sure do ![]() |
