eecee wrote:
I'm in WA. I've looked on the minecraft site and their next meeting is in April. I'd like to do a bit of research beforehand.
In terms of holding value and being collectible, Should I be looking only at australian ones or are jap imports ok...?
Eg on car sales at the moment there's a black one that is "1 of 500 remade by John Cooper Garage Ferring" ..... And another "genuine police special MkII". Can I trust these claims or are there a lot on imitations.?
There are lots of imitations.
The 1965 - 1971 Aust Morris Cooper S is easily faked/reshelled and you will need an experienced mini enthusiast to show you where to look and what to look for. If you want original you will need help. Most people selling a genuine Cooper S will actually go out of there way to prove that it is. When you get excuses like "the previous owner said it was" then be careful.
The most faked are the early MK2 Cooper S from May 1969 to Dec 1969 as they were only identified by a series of letters and numbers on the radiator support panel. They did not have Compliance plates. These cars are from YG2S4 501 and YG2S4 1400.
The next easiest to fake are the 1965 - 1969 MK1 Cooper S. They have a body number stamped into the firewall behind the master cylinders from 501 to 5486. Above the body number is an ID plate. This plate is not used or required for rego and blanks can be purchased.
There are dozens if not 100's of things that need to be checked so ask as many questions as possible.
We have a few registers that are worth having a look at here.
viewforum.php?f=43
