It is currently Sun Jul 20, 2025 9:04 pm
PostPosted: Fri Apr 01, 2016 1:29 pm
Does anyone know when the screen demist vents on the Cooper S, the part that is just under the dash rail not the retaining plate on top, were changed from metal to plastic?
johnl
PostPosted: Fri Apr 01, 2016 8:47 pm
Someone must have an idea
johnl
PostPosted: Sat Apr 02, 2016 8:14 am
My 67 S had plastic
PostPosted: Sat Apr 02, 2016 8:27 am
My april 66 has steel
PostPosted: Sat Apr 02, 2016 1:18 pm
June 69 is (Edit:) Steel with a steel heater
PostPosted: Sat Apr 02, 2016 3:01 pm
All 3 of my Mini K's had steel ones?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Apr 02, 2016 4:11 pm
My Sept. 1970 MK II S has plastic vents.
On the topic of demister vents it appears the Cooper S did not comply with ADR15 Demisting of Windscreens which came into effect on 1st January 1971. A deflector inserted into and attached to the demister vent apparently solved the problem by directing warm air into areas not previously covered.
Users browsing this forum: Phil 850 and 78 guests
