engine / fuel problem its back again arrggg help https://www.ausmini.com/forums/viewtopic.php?f=2&t=9232 |
Page 1 of 3 |
Author: | benjamin [ Tue Jul 19, 2005 3:36 pm ] |
Post subject: | engine / fuel problem its back again arrggg help |
in the last couple of weeks i have had a problem with my car that seems to be happening more often. after highway driving if i go to stop at a set of light the car stalls and is very hard to start again. first time it happened i put my foot on the clutch to stop at a set of lights and the engine stalled , it started 5 min later after pumping the accelerator and using the choke ![]() ![]() it is driven nearly everyday and starts without a choke and bearly any throttle most times |
Author: | Dylans Clubby [ Tue Jul 19, 2005 5:38 pm ] |
carby might need a cleanout/rebuild. i had a similar problem, a rebuild rectifyed it pretty quick! |
Author: | Wholetthesmokeout [ Tue Jul 19, 2005 5:48 pm ] |
Have you checked your fuel filter by any chance? |
Author: | benjamin [ Tue Jul 19, 2005 5:56 pm ] |
lol thanyou ![]() ![]() ![]() thanks for the help |
Author: | benjamin [ Fri Jul 22, 2005 5:02 pm ] |
anyway problem seems to have come back so im thinking its maybe the fuel pump as the filter seems pretty empty when engine is running how much is a fuel pump kit or a new one as my spare dont work ![]() edit> it is mechanical |
Author: | gafmo [ Fri Jul 22, 2005 5:41 pm ] |
I would also a Fuel filter is choked...as the presure from the pump would keep it running normaly Make sure you have a filter Before the Pump as it stops the crape getting into the pump ![]() this is for Mec or Electric...I'd say you would have crap in your Mech pump also Cant say I have any experiance with Mech pumps but atleast the electrice you can clean out..Sorry.I would say a filter is blocked ![]() |
Author: | mikkis37 [ Fri Jul 22, 2005 6:08 pm ] |
mech pump real easy to rebuild but pain in the arse to get out. Kit for rebuild cost me $49 or somewhere bout that. Easy and quick to do. Just remember to push the arm all the up before tightening right up! Good luck if you have a go! ![]() |
Author: | ryan [ Fri Jul 22, 2005 6:39 pm ] |
hey New kit will cost bout $36, getting the pump of isnt too bad, its getting the nuts done up again when u put it back on thats the prob, have fun, its not a hard job, but be prepared for a few cuts and scratches Cheers Ryan |
Author: | coops [ Fri Jul 22, 2005 7:08 pm ] |
leave the mechanical one where it is and buy a electric one super cheap has pierburgs for under $100 (maybe $75) auto electrician charged me like $120 or somthing along those lines ![]() |
Author: | Morris 1100 [ Fri Jul 22, 2005 7:51 pm ] |
Before you spend any money on things that may not fix the problem (and create even more problems) find out what the problem is! If you think it is the fuel filter then take off the filter! ![]() When the car is mucking up stop the engine and take the lid off the float bowl and see if there is any petrol in the bowl. Check the fuel pump by pumping fuel into a container (like a coke bottle) while spinning the motor with the starter. It will spin better with the spark plugs out but take the wire off the coil so you don't have a lot of sparks flying around with fuel pumping out vapour! Don't fit a filter before the pump. Don't fit an electric pump. Try fo fix problems not create problems. |
Author: | drmini in aust [ Fri Jul 22, 2005 7:56 pm ] |
If you have a Ryco fuel filter, they don't usually fill, they run with an air bubble in the top. As Anton found out when he sucked on the line.... blechhh.. spew... ptooey! ![]() |
Author: | J_A_M [ Fri Jul 22, 2005 7:59 pm ] |
hey Ben.....I bought a new SU mechanical fuel pump from Minisport (ebay) for $45 + $6.50 delivery. It is SWEEEEET as!! Damn good price too. He has another on ebay at the moment. I say for that $$$ buy it! |
Author: | J_A_M [ Fri Jul 22, 2005 8:02 pm ] |
drmini in aust wrote: If you have a Ryco fuel filter, they don't usually fill, they run with an air bubble in the top. As Anton found out when he sucked on the line.... blechhh.. spew... ptooey!
![]() ![]() ![]() ![]() By the way Ben, the good Doc tells me you don't have to 'pump' the accelerator when starting a car with an SU. It's true!! I don't do it any more and I find Pops and JAM start BETTER by just turning the key ![]() |
Author: | benjamin [ Sat Jul 23, 2005 10:05 am ] |
iv already changed the fuel lines and filter to new ones and when its running the fuel filter is only like 1/10 full thats why i though id changed the pump ![]() any ill try that non accelerator starting method too ![]() |
Author: | benjamin [ Tue Aug 02, 2005 3:15 pm ] |
ok problem happened again going to change the cap and rotor on my pulsar dissy this afternoon what else could be causing this? |
Page 1 of 3 | All times are UTC + 10 hours |
