Door hinges, round nose, just checking https://www.ausmini.com/forums/viewtopic.php?f=2&t=93191 |
Page 1 of 2 |
Author: | Stev0 [ Mon Jul 18, 2016 9:59 pm ] |
Post subject: | Door hinges, round nose, just checking |
Hi, I am just checking that there are 1" and 1.25" studs, 1/4" phillips screws (with wedged spacer on the upper hinge), as well as a bolt on the bottom hinge fixing the hinges to the door and body. I can't quite believe it was designed this way but probably was. Steve. |
Author: | gtogreen1969 [ Mon Jul 18, 2016 10:33 pm ] |
Post subject: | Re: Door hinges, round nose, just checking |
I can't remember how long the studs should be but here are the depths of the holes. Looking at my photos I had about 3/4" of thread sticking out, so 1" and 1.25" sounds about right. The only depth you really need to worry about is the screw/bolt that goes into the leading edge of the door. It is something like 3/4" long. The tapered washer goes on the top hinge - rear stud. Great idea that was. If your doing hinges there is some info here that may help. http://www.drjing.com/Mini/BLOG/DoorHang.htm http://www.drjing.com/Mini/TechFiles/HingeRebuild.htm |
Author: | Stev0 [ Tue Jul 19, 2016 12:07 am ] |
Thanks for that; sounds about right. But is there meant to be a bolt on the lower hinge closest the pin, body side (as my car seemed to have) or a stud? It doesn't really matter but I'd prefer to have it as it is meant to be.... |
Author: | gtogreen1969 [ Tue Jul 19, 2016 1:08 am ] |
Hows this sitnlo62 wrote: David,
Here is a diagram of the way the hinge bolts, studs and washers should be. it is correct! Note stud length and washer and spacer positions are shown for both upper and lower hinges. Hope this is of some use to you. Dave ![]() |
Author: | Stev0 [ Tue Jul 19, 2016 5:22 am ] |
That's good, thanks. But it's if anything more confusing! I found all the screws to be the same size, about 20mm or so... and the end studs were the same size in the upper/lower hinges, as were the central two studs (1.25"). Is there really meant to be a wedged washer in the upper end stud? |
Author: | Bill B [ Tue Jul 19, 2016 8:38 pm ] |
I am also about to replace doors to body; also interested in these details as I know all the studs are different lengths - due to having wedged spacers on upper hinges at least. My main question is about the setscrew (top and bottom hinges) that is visible in the door leading edge - is it pan head or hex? |
Author: | winabbey [ Tue Jul 19, 2016 10:10 pm ] |
This is from the most accurate of the round-nose Mini parts books. Note that what's missing from the diagram but present in the list of part numbers is the large thin flat washer (MYH103) that goes behind the rearmost stud of the upper hinge, visible in Greg's hand-drawn diagram. This helps to spread the load in an area of the door skin that's relatively unsupported as it's a long way from the door frame. Apparently these sometimes fall down deep in the door pocket when hinges are removed and are then left off on reassembly. I can interpret the bolt, washer, screw, etc. specifications from the part numbers if it's of interest. Attachment: PUB1012 RC02 L.jpg Attachment: PUB1012 RC02-1 R.jpg
Author: | Stev0 [ Tue Jul 19, 2016 10:52 pm ] |
I'm not surprised it's that complicated. Is it possible to determine the lengths of the screws and studs? I'm replacing the studs. |
Author: | Bill B [ Wed Jul 20, 2016 10:42 am ] |
winabbey wrote: I can interpret the bolt, washer, screw, etc. specifications from the part numbers if it's of interest. Is this the code? For PMZ410 and PMZ412: P= pan head M= metal thread ( yes/no?) Z= zinc plated 4 = diameter by 1/16th inches 10= length by 1/16th inches If so then I have an answer on the type of screw on the door front edge. But length of the studs isn't shown as they are part of the hinges. |
Author: | Stev0 [ Wed Jul 20, 2016 11:59 am ] |
Yes, but bizarrely the lengths of screws are in 1/16", bolt in 1/8" PMZ410 Pan head, 5/8" long PMZ412 Phillips 3/4" HZS405 Hex Bolt 5/8" long. |
Author: | drmini in aust [ Wed Jul 20, 2016 12:11 pm ] |
I just bought 1/4 unf x 2" long grade 5 plated hex screws, screwed them in and cut to length. (Edit) I cut the heads off to make them studs. |
Author: | winabbey [ Wed Jul 20, 2016 1:15 pm ] |
According to the BMC Australia Standards document: PMZ410 is Recessed Pan-Head Screw Unified, Zinc Plated, 1/4" diam x 5/8" long, UNF 28 tpi PMZ412 is the same but 3/4" long I haven't found a separate part number for the studs. |
Author: | Stev0 [ Wed Jul 20, 2016 2:32 pm ] |
Yes, you could just use bolts but that's too easy and sensible. |
Author: | Bill B [ Thu Jul 21, 2016 9:06 pm ] |
winabbey wrote: According to the BMC Australia Standards document: PMZ410 is Recessed Pan-Head Screw Unified, Zinc Plated, 1/4" diam x 5/8" long, UNF 28 tpi PMZ412 is the same but 3/4" long What does a "Recessed Pan-Head" look like? |
Author: | winabbey [ Fri Jul 22, 2016 10:28 am ] |
Bill B wrote: winabbey wrote: According to the BMC Australia Standards document: PMZ410 is Recessed Pan-Head Screw Unified, Zinc Plated, 1/4" diam x 5/8" long, UNF 28 tpi PMZ412 is the same but 3/4" long What does a "Recessed Pan-Head" look like? Attachment: BMC Std S5.jpg
