I need a bit of help.
In the next month I will be welding the new front panels onto SC850.... so naturally, I have been searching high and low for a diagram that shows the correct reference point locations.
I plan to have the body (on perfectly flat ground) resting on adjustable stands to get the car and the new front panels to line up properly. I have come across the following diagram which has all the measurements I am looking for..... all except for one problem.
Here is the reference pic....
http://mk1-performance-conversions.co.uk/images/vertical_drop_dia.jpg
These measurements do not start at ground level, but infact from a line that appears to be an inch or 2 above the ground - labelled as "X", or the DATUM LINE.
Firstly - Why is this line not at ground level?
Secondly - Assuming that this line is parallel to the ground (the bottom of the tyres, whatever), all I need to do is leave the wheels off to get the body closer to the ground (or in this case, to lower the datum line to ground level)..... am I right????
Hmmm.... so I wont need the subframes fitted to do all this either..... sounds promising!
Sorry, I just need other people to read and confirm this for me... I feel like it is too easy to be true. Bloody alcohol.
