It is currently Sun Jul 20, 2025 9:59 pm
 Post subject: Stainless door moulds
PostPosted: Sun Aug 28, 2016 2:39 pm
Hi all what's the best and eaisiest way to get the stainless chrome moulds on around the door frame. Without damaging the door paintwork or adjacent panels
PostPosted: Tue Aug 30, 2016 4:04 pm
I was interested to see the posts that were made in here...maybe no-one has found a way of doing it without damaging the door paintwork. I certainly scratched the bejeesus out of the paint under the chrome trim that went on the door surrounds as they are such a tight fit.
I'm sure some of the other mistakes I made are avoidable though and I'm shitty that I did them - eg the sharp corners of the outside chrome strip that runs horizontally along the bottom of the window aperture and quarter window. It left a mark you can see too, dammit :(
PostPosted: Tue Aug 30, 2016 4:39 pm
This has been discussed several times. Try a few searches. :wink:
PostPosted: Tue Aug 30, 2016 4:53 pm
Online
I can't do links, but search "How do you remove door chrome" 31 Aug 2014 in Mini Chat;
also "Stainless metal door trim round nose" 23 May 2016.
Both include replacement suggestions.
PostPosted: Tue Aug 30, 2016 7:44 pm
Like this Bill B
viewtopic.php?f=2&t=87048&hilit=How+do+you+remove+door+chrome
viewtopic.php?f=2&t=92705&hilit=Stainless+metal+door+trim+round+nose
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Aug 31, 2016 5:01 pm
Online
Thank you Scoop.
You are obviously under 60!
Where do you get the view topic and data?
Bill
PostPosted: Wed Aug 31, 2016 5:35 pm
Bill B wrote:
Thank you Scoop.
Bill
Where the "www.ausmini.com/forums" link at the top of the page is, just select all the text, then copy and paste.
E.g. this page is:
"http://www.ausmini.com/forums/viewtopic.php?f=2&t=93594"
The forum then changes the website link to look like below.
PostPosted: Wed Aug 31, 2016 6:13 pm
timmy201 wrote:
... then copy and paste.
Bill - and just in case you unaware of the keyboard shortcuts ... :wink:
On a Windows computer hold down the Ctrl key and press the C key to copy the highlighted text to the clipboard. Put your insertion pointer where you want the data pasted, hold down the Ctrl key and press V to paste the clipboard contents.
PostPosted: Thu Sep 01, 2016 8:13 pm
Online
Thank you all for your tutorial.
Timmy: Just found the topic link- it looked different until highlighted.
Winabbey: Thanks- this is an Apple; did know that about PCs as we used them when I worked.
