Cleaning wheels https://www.ausmini.com/forums/viewtopic.php?f=2&t=9393 |
Author: | Dylans Clubby [ Sat Jul 23, 2005 1:53 pm ] |
Post subject: | Cleaning wheels |
hey "peeps" ![]() how would i go about shining my wheels (contessas) up? i think the actualmetal is tainted or damaged or soemthing, nothing a good olish wouldnt normally fix up. but metal polish isnt doing much ![]() ![]() how much would beadblasting cost do you think? will the rubber need to come off??? edit: OR should i paint them silver? and mask off the rubber???? I dont want them chromed, i like the brushed metal look ![]() |
Author: | Smokie [ Sat Jul 23, 2005 3:03 pm ] |
Good question Dylan's Clubby as I was thinking the same myself. I spent about 1/4hr on each contessa cleaning them with WD40 and a bit of light wet & dry. They looked a lot better but probably would look heaps better if done professionally.. |
Author: | poeee [ Sat Jul 23, 2005 3:12 pm ] |
You can get em bead blasted. It's like sand blasting, but with fibreglass beads, which are better for the alloy than the normal sand that sand blasting uses. That's the extreme though. |
Author: | 9YaTaH [ Sat Jul 23, 2005 4:48 pm ] |
Post subject: | Alloy Wheels |
I heard a tip the other night...sometimes tyres refuse to seal correctly on alloy rims...so you get slow leaks.... answer is to have the inner rim powdercoated to provide a better seal. Anyone heard of this one? |
Author: | gafmo [ Sat Jul 23, 2005 4:57 pm ] |
Yer bead or sand blasting can can affect the tyre's holding the pressure...just get them polished up afterwards. you will find you will wont to polish the exteria of the wheels after anyway. Use differnt grades of Wet and dry and then finish off with Autosole also a good thing is to lath the edge so it nice and even Yes it does take some time but you will love the finish after |
Author: | benjamin [ Sat Jul 23, 2005 4:58 pm ] |
i cleaned my wheels with a wire brush on a drill then washed them then masked the tyre and outer rim( i kept that plain alloy) painted with etch primer and then with whaterver paint you want then the masking is removed and i polised the outer part of the rim and they look great ![]() |
Author: | Dylans Clubby [ Mon Jul 25, 2005 9:15 pm ] |
scott, where can i gte them bead blasted? will the rubber need to come off? considering taking it back a little with some wet/dry, then metal polish. i like the colour of the metal, i dont want to paint it. unless maybe if i coat it in varnish???? |
Author: | min13k [ Mon Jul 25, 2005 9:31 pm ] |
9y when i was a tyre fitter in another life there was a rubber like compound we used on mag wheels that had this problem paint it on leave for twenty odd mins then refit tyre makka |
Author: | drmini in aust [ Mon Jul 25, 2005 9:44 pm ] |
Mick, Some mags are porous but Contessas are pretty good in that respect. I've got 3 sets, one wheel is corroded a bit inside (because had tube once & water got in) but even it doesn't leak. Cleaning the Contessa's rim bit is easy- put wheel in lathe, turn gutter rash off, polish inside rim with 600 then 1200 wet/dry. Then later hit it with Mothers metal polish or whatever. The spokes? I just paint stripped them, then etch primer & VHT Quick Coat Black. To polish those you must be a Bling! merchant... ![]() |
Author: | min13k [ Mon Jul 25, 2005 9:52 pm ] |
you can bye a deoxcidiser non acid type i know california gold makes it same people who make purple in sydney at chipping norton there is a place that has it but not sure on the price ![]() maklka |
Author: | h0nk [ Tue Jul 26, 2005 2:11 am ] |
I've got gold rims... but the paint seems to be coming off them... what is the best way to get them looking good again? just paint over? If I just strip the paint off, how much would it cost to get them powder coated gold? |
Author: | drmini in aust [ Tue Jul 26, 2005 7:17 am ] |
If the gold paint is coming off they need stripping off, & etch priming. Make sure you use an etch primer suited to aluminium. Zinc chromate is good. ![]() |
