It is currently Fri Jul 18, 2025 3:27 am
PostPosted: Tue Aug 02, 2005 10:08 pm
How much power have you guys made out of a 1100 fitted with 1-1/2" Su? please detail other mods done to motor to get total figure.
Just doing some home-work
Cheers! :D
68' Morris, 1100,
Willson Automotive
Tasmania's ONLY mini Specialists
(03) 62725056
http://photobucket.com/albums/a323/the_white_one/
PostPosted: Tue Aug 02, 2005 10:27 pm
bog stocko 1100 clubman = 50 HP at the flywheel
37.5 Kilowatts
oh i should say a single 1+1/2" SU is only good to about 70-75hp max,
but i'd go to a 1+3/4" at about 60-70hp
they're fine at low rpm but cant feed enough at high rpm on a high output motor.
PostPosted: Tue Aug 02, 2005 10:55 pm
Running the twins plus ported 295/202 head will give enough poke for some fun 8)
