Engine Capacity?????
https://www.ausmini.com/forums/viewtopic.php?f=2&t=9493
Author:  mini_van_1970 [ Tue Jul 26, 2005 6:11 pm ]
Post subject:  Engine Capacity?????
Ok I was just wondering what size the engine capacity goes to once bored out to certain thousands of an inch
eg: 850 .020" = ........
.040" = ........
.060" = ........
etc,etc,etc
Just out of curiousity
the doc might (probaly) would know
Pat
Author:  benjamin [ Tue Jul 26, 2005 7:06 pm ]
i just worked these out so not sure how correct they are
850 is actually 848cc
+20thou = 863.3cc
+40thou = 877.2cc
+60thou = 891.2cc
998
+20thou = 1015cc
+40thou = 1030.4cc
+60thou = 1046.5cc
1098
+20thou = 1115cc
+40thou = 1132cc
+50thou = 1141cc (thas what mine is)
+60thou = 1152cc
if you want any more ill calculate them for u :wink:
Author:  drmini in aust [ Tue Jul 26, 2005 8:11 pm ]
For a 1098 you can now get +.080" Hypatec flat tops again. Lovely... 8)
These will give you 1162cc.
Graham Russell has them. :wink:
Author:  rampage101 [ Tue Jul 26, 2005 8:44 pm ]
Any idea on price for them Doc? Would they be suitable for a turbo buildup?
Author:  mini_van_1970 [ Tue Jul 26, 2005 8:53 pm ]
I wouldn't think thatit would be wise to run a turbo because at that capacity the walls of the bores would be to thin and I wouldn't like to be there when it blew up
Hey ben what is the bores for a 1275cc?
Pat
Author:  drmini in aust [ Tue Jul 26, 2005 8:53 pm ]
Sorry no idea on price really, & for turbo the C/R would probably be too high. You need some nice dished ones... :wink:
Author:  mini_van_1970 [ Wed Jul 27, 2005 9:31 pm ]
So I'll just bump this up here. Hopefully find out what the capacity would be for a 1275cc engine that has been bored out 20,40,60thou and so on if anyone knows
Pat
Author:  justminis [ Wed Jul 27, 2005 9:43 pm ]
+0.020" = 1293
+0.040" = 1310
+0.060" = 1330
bore to 73mm = 1360
bore to 73.5mm = 1380
bore to 74mm = 1400
edit: assumes std stroke.
Author:  drmini in aust [ Wed Jul 27, 2005 9:49 pm ]
And the 74mm ones appear to be unobtainium now. :cry:
Steve you forgot 74.7mm, (Triumph 2.5PI) 1426cc... 8)
Block's getting a bit thin, isn't it...
Author:  1380 yellow devil [ Thu Jul 28, 2005 8:05 am ]
Very thin may even break into the oil ways.
