Van Weights
https://www.ausmini.com/forums/viewtopic.php?f=2&t=9505
Author:  djhaddo1 [ Wed Jul 27, 2005 9:29 am ]
Post subject:  Van Weights
Just trying to find out how much difference there is between the weight of the van and saloon. I know the deluxe is listed as 630kg, there can't be too much difference but I can't find it listed in my books. :oops:
Anyone have an idea?
Dan
Author:  mini_van_1970 [ Wed Jul 27, 2005 9:47 am ]
I think that the weight of a van is about 615kg but I am unsure doc would know and most other people with vans might be able to tell you but I am preety sure it is 615kg
Pat
Author:  WhoDat [ Wed Jul 27, 2005 9:47 am ]
From the Haynes manual
Weights
Kerb weight:
Saloon (rubber cone suspension):
Manual transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 638 kg
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 658 kg
Saloon (Hydrolastic suspension):
Manual transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 679.5 kg
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 699.3 kg
Estate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 686.7 kg
Van . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 621.5 kg
Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 622.4 kg
Maximum towing weights:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 404 kg
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 303 kg
Maximum towing hitch load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 kg
Maximum roof rack load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 kg
Cheers Dat
Author:  djhaddo1 [ Wed Jul 27, 2005 11:18 am ]
Cheers guys.
Bit of a trip that the van can tow less than the saloon. :shock:
Author:  WhoDat [ Wed Jul 27, 2005 11:22 am ]
I think that they would be making allowances for all the extra weight the Van could be carrying in its cargo area compared to a sedan boot - [only a guess]
Author:  djhaddo1 [ Wed Jul 27, 2005 11:43 am ]
You're probably right whodat.
Were the vans hydro or rubber cone?
Author:  bnicho [ Wed Jul 27, 2005 12:38 pm ]
All vans/utes/estates were dry suspended (from the factory anyway!)
Author:  Mini Mad [ Wed Jul 27, 2005 12:40 pm ]
I believe Van's were rubber cone..
They're also heavier than sedan's..don't believe haynes ;)
See here:
http://www.ausmini.com/forums/viewtopic.php?t=7497&postdays=0&postorder=asc&highlight=van+weight&start=0
Author:  67'MiniVan [ Wed Jul 27, 2005 1:52 pm ]
According to my original owners manual (Mk1 '67 model Van)
Van = 1390 lbs = 630.4933943 kilograms.
Cooper S = 1411 lbs = 640.01883407 kilograms
Moke = 1255 lbs = 569.25842435 kilograms
De Luxe = 1435 lbs = 650.90505095 kilograms
I actually have a (registered+accurate) weigh bridge at home, maybe I should use it...
Author:  Mini Mad [ Wed Jul 27, 2005 2:00 pm ]
Yea, weight them, would be good to know...
Author:  jill200sx [ Wed Jul 27, 2005 2:06 pm ]
and from the Manual that I downloaded from somewhere on this forum ;)
Dimensions
Overall length:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3054 mm
Clubman Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3165 mm
Cooper (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3061 mm
Estate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3403 mm
Van . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3298 mm
Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3314 mm
Overall width:
All models except Cooper (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . 1410 mm
Cooper (1990-on) including mirrors . . . . . . . . . . . . . . . . . . . . . . . . . . 1560 mm
Overall height:
Saloon:
Pre-1985 models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1346 mm
1985 models-on . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1353 mm
Cooper (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1331 mm
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1359 mm
Wheelbase:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2036 mm
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2134 mm
Weights
Kerb weight:
edit: same as Whodats figures, prolly same Manual, but dimensions for anyone whos interested
Author:  bnicho [ Wed Jul 27, 2005 4:27 pm ]
My van was 660kg on the weighbridge in 2000, but that was with added weight of a wood dash, extra gauges, carpet etc etc. :)
Author:  Gilly [ Wed Jul 27, 2005 6:31 pm ]
A bit out of topic but the Van weight is very comparable to my 1200 ute at 670kg
Author:  min13k [ Wed Jul 27, 2005 6:38 pm ]
40 kg on the roof huh
i know a guy who used to carry h and i beams on the roof of his mini
bob also knows him
that'll do young fella
makka
Author:  WhoDat [ Wed Jul 27, 2005 8:36 pm ]
Minimum me weight. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 kg [at the time LOL]
I used to regularly sit on the roof rack while out spotlighting :lol:
