Morris 1300 engine https://www.ausmini.com/forums/viewtopic.php?f=2&t=9518 |
Page 1 of 2 |
Author: | KiwiMR2 [ Wed Jul 27, 2005 4:18 pm ] |
Post subject: | Morris 1300 engine |
I THINK I have scored a 73 Morris 1300......I've been told this should fit into my mini 1000 (82 round nose)....the motor that is ![]() I can't seem to find much info about this motor.....anyone know anything?? I think I've worked out it's an AD016 body etc. much like this: ![]() Cheers KiwiMR2 |
Author: | rampage101 [ Wed Jul 27, 2005 4:58 pm ] |
Did you google at all? First link: http://www.motorbase.com/vehicle/by-id/1089/ Yes, A-Series 1275 'Detuned Mini Cooper engine' (website fact) Probably just need to change the engine mounts. |
Author: | TK [ Wed Jul 27, 2005 5:12 pm ] |
Here in Oz the Morris 1300 was an auto. If you want to convert to a manuel there are procedures in the Mini Mod zone. |
Author: | KiwiMR2 [ Wed Jul 27, 2005 5:25 pm ] |
rampage101 wrote: Did you google at all? First link: http://www.motorbase.com/vehicle/by-id/1089/ Yes, A-Series 1275 'Detuned Mini Cooper engine' (website fact) Probably just need to change the engine mounts. I swear I googled....for like 20 mins and read lots of bits and peices but didn't get any detail about the motor ![]() Quote: Here in Oz the Morris 1300 was an auto. If you want to convert to a manuel there are procedures in the Mini Mod zone.
This one is a manual ![]() I JUST picked it up and drove it home, rego & warrant JUST expired last month & he didn't bother getting one as some vandals smashed the rear tail lights and kicked in the boot area etc. There were NO idicators so I got the missus to follw me home (5 min drive) ONE min into the return trip I get pulled up ![]() ![]() BLODDY lucky. Seemed to pull ok, bit sputtery but has like NO fuel left in it. Cheers KiwiMR2 |
Author: | 9YaTaH [ Wed Jul 27, 2005 6:16 pm ] |
Post subject: | Re: Morris 1300 engine |
KiwiMR2 wrote: I can't seem to find much info about this motor.....anyone know anything?? I think I've worked out it's an AD016 body etc. much like this:
![]() Cheers KiwiMR2 That looks suspiciously like an MG1100....there is a picture of the one I drove to Wheels 2004 or 5 in Canberra...check the Events folder. If so, it might be a good idea to leave it as it is....close ratio gearbox, twin SUs and 1275...also known as an Austin America???....anyway, well worth preserving for what it is mate ![]() ![]() |
Author: | KiwiMR2 [ Wed Jul 27, 2005 7:20 pm ] |
Looking at it now I have it and seeing that pic it's not quite the same. Is as far as I can tell identical to this: ![]() ![]() ![]() Im told the unit is and older pre A+ engine, and will have remote change, so I'll have to change the gearbox to make it fit my shell.....sound right?? Cheers KiwiMR2 |
Author: | drmini in aust [ Wed Jul 27, 2005 7:24 pm ] |
Here in Oz they called it an 1100S even though it was a 1275. Just to confuse everybody and trade on the S name.... Elsewhere in the world it was called a 1300, or Austin America (which was a 2 door ADO16 body). They finally called the auto a Morris 1300 here, to distinguish it from the Morris 1500 OHC POS. ![]() |
Author: | poeee [ Wed Jul 27, 2005 7:24 pm ] |
It's the equiv to our 1100 S I would say. Search for Morris 1100, you'll get plenty of info. Engine is the same as the Mini's, but brakes can't be used without modification. |
Author: | KiwiMR2 [ Wed Jul 27, 2005 7:30 pm ] |
Are they right about the gearbox?? So for $125 it sounds like a good buy, even just for the motor?? Cheers KiwiMR2 |
Author: | drmini in aust [ Wed Jul 27, 2005 7:35 pm ] |
Gearbox will fit, but remote mounting has a rubber sandwich plate in between to make the shift feel crappy and imprecise. MiniMania site sells a solid sandwich mount, which rectifies this. You will need to fit a Mini engine mount & bracket to the radiator end of gearbox, and fling the old 1300 mounts. Also fit a `Mini remote shift' rubber mount to the end of extension housing. Diff ratio will be a bit low, I'd bung a 3.44 in there while it's out. ![]() |
Author: | Morris 1100 [ Wed Jul 27, 2005 7:43 pm ] |
It is a Mk2 car not like the Mk1s that we had in aus. Being a late car it could have a rod change gearbox, does it have a puddle of oil under the rear of the gearbox? ![]() If it has a rod change you should be able to keep the gearbox. |
Author: | KiwiMR2 [ Wed Jul 27, 2005 7:47 pm ] |
drmini in aust wrote: Gearbox will fit, but remote mounting has a rubber sandwich plate in between to make the shift feel crappy and imprecise.
MiniMania site sells a solid sandwich mount, which rectifies this. You will need to fit a Mini engine mount & bracket to the radiator end of gearbox, and fling the old 1300 mounts. Also fit a `Mini remote shift' rubber mount to the end of extension housing. Diff ratio will be a bit low, I'd bung a 3.44 in there while it's out. ![]() Hmmm.....some of that goes right over my head ![]() To be honest the gear changes in that were MUCH nicer than my current mini, which is sad as I spent like $1300 on that gearbox ![]() $89.95 US dollars isn't to bad aye. The Mini engine mount & bracket etc...can't I use the one in my mini now?? What will the different diff do to the actual feel driving the car?? Cheers KiwiMR2 |
Author: | 9YaTaH [ Wed Jul 27, 2005 7:52 pm ] |
Post subject: | Low Diff... |
KiwiMR2 wrote: drmini in aust wrote: Gearbox will fit, but remote mounting has a rubber sandwich plate in between to make the shift feel crappy and imprecise. MiniMania site sells a solid sandwich mount, which rectifies this. You will need to fit a Mini engine mount & bracket to the radiator end of gearbox, and fling the old 1300 mounts. Also fit a `Mini remote shift' rubber mount to the end of extension housing. Diff ratio will be a bit low, I'd bung a 3.44 in there while it's out. ![]() Hmmm.....some of that goes right over my head ![]() To be honest the gear changes in that were MUCH nicer than my current mini, which is sad as I spent like $1300 on that gearbox ![]() $89.95 US dollars isn't to bad aye. The Mini engine mount & bracket etc...can't I use the one in my mini now?? What will the different diff do to the actual feel driving the car?? Cheers KiwiMR2 Yes you can probably use your existing mounts...just can't use the ones off the 1300.... The diff is probably a stump puller mate....it will rev its little head off...they were meant to be a town car...an English Town!! ![]() |
Author: | drmini in aust [ Wed Jul 27, 2005 7:55 pm ] |
And they were geared for 12" wheels with HIGH profile rubber.. ![]() |
Author: | 9YaTaH [ Wed Jul 27, 2005 8:02 pm ] |
Post subject: | 30 clicks |
drmini in aust wrote: And they were geared for 12" wheels with HIGH profile rubber..
![]() So low profile rubber would improve the acceleration ![]() Lots of towns in NZ go from 50 to 30 zones in the built up areas last time I drove there...so very English Town speeds anyway ![]() |
