Got everything hooked up again and whee no start.
checked leads 1,4,3,2 (does it matter which plug #1 goes into on the cap so long as they are in the correct order? Also checked the direction the rotor spins and plugs are currently hooked up in the correct order and direction).
Getting a spark at the plugs.
Getting fuel pumping through the inlet pipe at the carby.
I've been trying to get it going since about noon, I pulled the plugs out and they are dry as a bone still so no fuel is getting to them.
I've read up and some threads say try pouring some fuel into the carby and seeing if that does anything? Am I pouring a bit into the air intake bit or somewhere else?
He's only been sitting there a month since I last started it
Shard
