It is currently Fri Jul 18, 2025 10:31 am
 Post subject: Marking cam followers
PostPosted: Mon Jul 31, 2017 11:24 am
Hi all
Nearly got the camshaft out but I need to take the cam followers out (I think?!?!).
Also taken out the distributor cog gear thing. And oil pump.
But do I need to mark which cam follower came out of which hole?
Thanks all.
PostPosted: Mon Jul 31, 2017 3:58 pm
Depends on if your intending to use the same cam again? If new or different cam then no because you need to use new followers.
PostPosted: Mon Jul 31, 2017 10:45 pm
Thanks minimans. That's a very concise answer.
Users browsing this forum: Bing [Bot] and 86 guests
