Changing locks in Sydney https://www.ausmini.com/forums/viewtopic.php?f=2&t=959 |
Page 1 of 2 |
Author: | IwannaMini [ Fri Jun 25, 2004 10:51 pm ] |
Post subject: | Changing locks in Sydney |
Sorry I couldnt find a post like it.... BUT.. For all of those of us in Sydney, has anyone changed their locks on their Mini and can anyone recommend someone or give me an indication of price..? I have the locks in the pull down handles, but I was able to open the car and start it firstly using a different Mini key, and then secondly with a key from a padlock off the gate..!!! ![]() Cheers..! |
Author: | willy [ Fri Jun 25, 2004 10:57 pm ] |
Yeah thats the joy of owning a Mini... figuring out the best ways to secure the bugger! ![]() I've lost the keys for the locks that are in mine, and havent been arsed to get a locksmith to key them back up; but i will very soon. ![]() I haven't parked it outside or left it alone at all when it's this vunerable don't worry. Now, i think i recall that someone got a new set of "hi-tech" more secure locks from karcraft? maybe. Can't remember, and im sure someone else would be more helpful than i have been! ![]() W. |
Author: | Miniless [ Fri Jun 25, 2004 11:20 pm ] |
Just go Mr. Bean styles and use a padbolt |
Author: | WhoDat [ Fri Jun 25, 2004 11:40 pm ] |
I heard the Solex Locks are good. Not sure about price but. http://www.speeding.co.uk/acatalog/Prod ... s_103.html |
Author: | boost_morrre [ Sat Jun 26, 2004 1:16 am ] |
Post subject: | just did mine last week |
i just put solex type ones in mine but they are APX brand... got them from auto one. price was 70-80 i think (but they were on sale for $25 cause they were stock taking) for three of them in a set with four keys....three normal and one without the notch just in case u over turn the lock when it is not installed so u can put it back in. easy to put in, just take the old ones out, change the clip on the back of the new one to a swivel type that comes with the pack, file away at the door a little (but not too much as you wanna make the new lock a very tight fit) then install them in by pushing them in hard and locking them in on the inside with a clip that also comes with the pack.... go down to your local auto one and see if they have anymore (universal) type APX locks....[the mini fitment ones are not in their database so i had to get universal ones that looked similar, obviously larger but definitely not smaller!) |
Author: | drmini in aust [ Sat Jun 26, 2004 7:31 am ] |
Sounds like you have fitted these to Clubbie doors OK- I doubt they will fit the earlier handles though. New lock tumblers and keys are on MiniSpares or ausdirect sites, but I dunno if they will fit Oz door handles either. Anybody done it? |
Author: | IwannaMini [ Sat Jun 26, 2004 9:57 am ] |
cheers for the advice so far. ![]() I think DrMini read my mind though... the description sounds like you have fitted new locks to a clubbie where the lock (from memory) is in the door. I have a '65 Deluxe which has those "high tech" locks in the handles. I am sure if I play I will realise what I need to replace but if someone has done it, the job is 3/4 done..!!! p.s. wgormly, I'm like you at the moment. I parked on the footpath outside the cafe I was at just so I could keep an eye on him..!!! p.p.s re that whole Mr Bean padlock style.... I did that on my old Mini... its murder on the paint work..! |
Author: | boost_morrre [ Sat Jun 26, 2004 1:17 pm ] |
sorry....stupid me didnt think that the locks in the roundies were in the handle.... ![]() |
Author: | ausminis4u [ Sat Jun 26, 2004 2:55 pm ] |
im gonna get sum solex locks from super crap, thay have em for about $40 ![]() |
Author: | dewey [ Sun Jun 27, 2004 10:49 am ] |
I reckon the solex locks would be good but they are huuuge. I need to pick up a complete set of locks cause I need three keys to turn the various locks in my car. dewey |
Author: | IwannaMini [ Sat Aug 21, 2004 3:36 pm ] |
OK door cards off, Mini in pieces, I have tried to tackle the door lock problem to no avail. Problem - turning the lock wont lock the door Investigation - there is a metal ring with a seperate hook attached that seems to have come loose. Hooking that up to the longer screw (all on inside of door) doesnt change things. there is a second ring (no hook) that also was moving around. Pushed that into the lock where the gap allowed. Still no change. So very frustrated ![]() ![]() Questions - 1. have i f'ked it..?? 2. Is there a way to remove the handle/lock without needing to pull the door apart..?? 3. Has anyone got a diagram of the pieces that they can send me..? The Hayes one seems totally different. P.s. The Solex locks definitely wont fit pre Clubman door handles. Solex locks will only fit as long as the Key Barrel is SEPARATE to the HANDLE.. |
Author: | drmini in aust [ Sat Aug 21, 2004 5:35 pm ] |
Better take it to a locksmith. ![]() I brought in some UK barrels and keys, but haven't had a chance yet to see if/how they fit Deluxe/Cooper S handles.. ![]() |
Author: | PhildoD [ Sat Aug 21, 2004 10:14 pm ] |
I know for a fact that ya can buy solex locks with a surround that sit out from the body a touch(suitable for clubbies), and they also have locks which are designed to replace the original ones in door handles. But I dont believe they make them for mini door handles, only more common later model cars now. |
Author: | drmini in aust [ Sat Aug 21, 2004 10:23 pm ] |
I brought in 24G1345, ignition barrel set MK1 & 2- (5.1GBP) and 27H9634- key barrel set Mk2. (8.00GBP for 2 sets) From MiniSpares. My assumption was that the keys and barrels were imported from UK even though the locks & handles were made in Oz. Dunno if they fit, yet.... ![]() I'm on hols next week- if I get time I'll try and fit 'em. Anyone know how to get the tumblers out of a Deluxe / S door handle?? ![]() |
Author: | gafmo [ Sat Aug 21, 2004 10:36 pm ] |
While your on Locks Imanamini, Guess wha I found in The tank Of Marcia ![]() Complete bottom end of a fuel locking Mech. I took he tank of and put it on the pround with a rattle rattle. Five minutes later Springs barrel and bottom end of cap on the ground. LOL realy. Good luck on the Door Locks Cheers Mate |
