It is currently Wed Jul 02, 2025 5:39 am
PostPosted: Tue Aug 15, 2017 9:07 am
This is an interesting new kit with fuel injection. It's good to know people are still thinking outside the box with new ideas for the market
More details on the post here:
https://www.facebook.com/specialistcomp ... 1459980285
A great day at MITP yesterday at Santa Pod. The newly released S-Pack Supercharged 5 Port EFI engine gained fantastic interest. We will be releasing full details and prices for this very soon. There will be a 'Kit' aswell as a complete crate engine available.
It will run our 5 port injection throttle body kit, the Rotrex supercharger with a new timing cover that also acts as a mount for the charger. This engine has been based on an MPI engine but won't be limited to an MPI engine.
Our system is dramatically different to anything else that's gone before. The fundamentals being we are compressing the air then adding the required fuel at the cylinder head rather than adding fuel before the supercharger and then asking the charger to distribute the fuel as it decides. This gives us accurate control of the fuelling as it's required allowing us to run stock compression ratios around 10.2:1 meaning most engines running moderate boost wouldn't need to even take the head off. The supercharger itself builds boost with revs allowing the pulleys to be sized to give the required boost for the engine spec and the rev range the engine will work with. The supercharger will flow enough air for 200hp, which means you can start with a mild set up and the charger will stay with you if you build for more power in the future. We will be Dtho testing many variations in Sept from stock mpi cam through the sw5 and then a re130t, again our experience with the Rotrex on TwinKam engines shows that they work as extreme power adders on top of typical n/a tuning, i.e. They love cam duration, big flowing heads, exhaust etc. Keep an eye out its gonna be fun.....
PostPosted: Tue Aug 15, 2017 10:37 am
3.5k GBP for the kit ><
Nick
PostPosted: Tue Aug 15, 2017 11:41 am
yeah, those little blowers are hugely expensive for what is basically half a turbo...
PostPosted: Tue Aug 15, 2017 7:50 pm
Wow it looks really tidy. That price is on par with a twin screw supercharger. Much more expensive than the second hand roots that most people use though.
Sent from my Nexus 6P using Tapatalk
PostPosted: Wed Aug 16, 2017 6:02 am
yes, the planetary gear box is the costly factor. beeing a crank driven turbo you still need to reach high RPM at the compressor
maybe someone wants to try current charger technology? http://www.rotrex.com/Home/Products/Var ... erchargers
Rover 214 atm ....
PostPosted: Wed Aug 16, 2017 9:01 am
Sure, if you pay for it ;) 8)
Nick
PostPosted: Wed Aug 16, 2017 12:18 pm
ahhh, so that's how they get the compression... I'd assumed it was something they'd done with the impeller...
that's a bit snazzy
