It is currently Fri Jul 18, 2025 3:22 pm
PostPosted: Thu Sep 21, 2017 9:51 pm
Where can I buy the rubber windscreen surround for a Mini laminated windscreen?
I bought one but it appears the groove is too thin and would only fit a standard zone toughened screen or back window.
PostPosted: Fri Sep 22, 2017 7:29 am
If no-one else responds you may need to get on the phone and ring around.
viewtopic.php?f=41&t=83593
PostPosted: Sun Sep 24, 2017 10:34 am
A few years ago I had trouble with a new seal that wouldn't let the glass fit into the frame because the seal was too full in the centre section.
Bought another from MG Spares in Smithfield that worked.
A long time ago I went to a laminated screen from a toughened type without changing the seal as the difference in glass thickness wasn't a problem. Might be different now.
PostPosted: Thu Apr 06, 2023 7:29 pm
You might have to get O'Briens to do it if there are no Mini Businesses that stock the rubber you need.
