It is currently Mon Jul 21, 2025 9:08 am
 Post subject: Plans For Rotissary
PostPosted: Sun Oct 01, 2017 3:56 pm
Just wondering if there were plans on the forum for making a rotissary so working on my Mini would be easier. I tried a search to no avail.
 Post subject: Re: Plans For Rotissary
PostPosted: Sun Oct 01, 2017 4:13 pm
Online
Searching using the term rotisserie brings up a lot of hits. I didn't check if any of the posts had plans, but there will be examples pictured.
PostPosted: Sun Oct 01, 2017 9:51 pm
I don't think a mini rotisserie has to be all that complicated, it's light enough if you make it reasonably strong it'll be fine.
I was worried about plans etc but in the end just made it out of scrap steel lying around mostly.
Use square to pickup the front subframe bolts on the crossmember another square section to pickup the shock mounts in the rear (i welded washers so it fitted in nicely) a piece of pipe to skewer the mini and you've mostly just the stands to go.
Slightly larger pipe for the pivots and I used the same slightly larger pipe to create lock rings (captive nut welded on).
The stands use some square, one slightly smaller than the other makes it height adjustable rotation locking is performed by a old Landcruiser vented disk rotor and a pin.
Here's a picture :
I put three castors each end on later to wheel the mini around on.
Roads need more corners
PostPosted: Mon Oct 02, 2017 5:38 am
The one I borrowed from a mate has the rear end of the pipe attached to a flange at the hole in the rear seat back.
However later cars don't have these holes so the pipe has to go through the screen openings.
PostPosted: Mon Oct 02, 2017 10:43 pm
Here's a picture :
Thanks for that.
I'm about to think about exactly these plans.
ALSO!!! Thank you for using "made out of scrap steel lying around...."
You have made an old "apostrophe man" very happy!
You weren't "laying" them anywhere, were you! (Very painful).
PostPosted: Mon Oct 02, 2017 11:02 pm
Lots of examples here
viewtopic.php?f=25&t=55421
Users browsing this forum: winabbey and 85 guests
