It is currently Fri Jul 18, 2025 5:54 pm
 Post subject: Remote shift tunnel hole
PostPosted: Sun Oct 29, 2017 10:29 am
Hi folks,
I’m hoping some nice person can measure their tunnel hole as I need to cut one in my car?
I guess the measurements I need are...
*Front of seat box to rear of hole
*length of hole, front to back
*right edge of hole from drivers inner sill
*left edge of hole from passengers inner sill
Thanks very much in advance,
Cheers, Silas :P
PostPosted: Sun Oct 29, 2017 12:21 pm
I may not qualify as a "nice person" but I'm happy to help. :)
With the tape measure hard against the front edge of the seat cross-member (top of the photo below) the hole starts at 40mm and ends at 160mm.
From the middle of the downwards curve on the right side of the old starter button flange to the right edge of the hole is 80mm.
The hole is 110mm wide measured along the curved tunnel, not straight across the opening.
The corners are smoothly rounded.
Give that a try. Let me know if you need more.
PostPosted: Sun Oct 29, 2017 7:15 pm
Yep, you definitely qualify as a nice person! Humble too!
Thanks so much :D
Silas
Users browsing this forum: No registered users and 122 guests
