carbs, whats the diff? https://www.ausmini.com/forums/viewtopic.php?f=2&t=965 |
Author: | grouse_bogun [ Sat Jun 26, 2004 9:01 pm ] |
Post subject: | carbs, whats the diff? |
How do you tell the difference between a 1 1/4 and 1 1/2 SU carb? Bit of a dumbass question...sorry..... ![]() |
Author: | willy [ Sat Jun 26, 2004 9:04 pm ] |
The big round chamber on the top is smaller on an HS2 than the HS4. You may have to compare them to find out. Unless their is an easier way. |
Author: | grouse_bogun [ Sat Jun 26, 2004 10:23 pm ] |
so a 1 1/12 is an HS4 ? |
Author: | drmini in aust [ Sat Jun 26, 2004 10:43 pm ] |
Yes an HS4 carb is a 1-1/2". As said, the dashpot on top is bigger than an HS2 (1-1/4"), also the mounting holes onto the manifold are diagonal on the HS4. Size is measured where it bolts to the manifold. Intake hole size is a bit smaller. |
Author: | grouse_bogun [ Sat Jun 26, 2004 11:01 pm ] |
thanks Kev. I thjink I have a 1 1/2 then. |
