Optimum Subframe Coating https://www.ausmini.com/forums/viewtopic.php?f=2&t=96759 |
Page 1 of 2 |
Author: | zulu_warrior1976 [ Tue Feb 06, 2018 7:54 pm ] |
Post subject: | Optimum Subframe Coating |
Hi All, Have been trawling the threads and see that there isn’t really a consensus on the best coating when refurbishing subframes. - POR15 is affected by brake fluid - Powder coating sheets off - etc What’s the best way to go? Zulu Sent from my iPhone using Tapatalk |
Author: | Scoop [ Tue Feb 06, 2018 8:16 pm ] |
Post subject: | Re: Optimum Subframe Coating |
I have been pretty happy with the KBS products. Black top or something I think. |
Author: | cruiser23 [ Tue Feb 06, 2018 8:21 pm ] |
I used KBS Rust Seal on the sub-frames which is a moisture cured urethane very similar (I believe) to POR 15. I am using Dot 5 brake fluid which wont eat paint. I have had the brake fluid overflow on to the body paint (2 pack) and the sub-frame with no affect. So far I am happy with my choices. |
Author: | Harley [ Tue Feb 06, 2018 8:34 pm ] |
I've not had issues with POR15 and brake fluid - even when I brushed it on on purpose to try and get it off! Haha! I've always just had my subframes sandblasted and painted with industrial / marine grade epoxy primer and top coat. My oldest one painted that way has been sitting in the backyard for a decade in the sun - it's a bit faded but otherwise still pretty good. |
Author: | Morbo28 [ Tue Feb 06, 2018 8:40 pm ] |
I'm a fan of POR15. No issues with brake fluid myself. Sent from my Pixel 2 XL using Tapatalk |
Author: | slacko [ Tue Feb 06, 2018 8:45 pm ] |
I had my subframes blasted I then used por 15 and over laid it with por 15 chassis black which is a mat finish Though as old boots spilt brake fluid on the front sub frame whiles changing a brake switch , had no effect on the paint Mark |
Author: | p7676 [ Tue Feb 06, 2018 9:36 pm ] |
No other way to go, grit blasting then powder coating .Not expensive .Por does go dull |
Author: | captainwaldopepper [ Tue Feb 06, 2018 9:51 pm ] |
I've used KBS rust seal on all mine so far and it is tough and doesn't chip off easily-also had no problems with brake fluid at all. I'm getting the subframes of my current project blasted and then powder coated at the moment. Mainly because it was cheaper and easier than painting them myself but i do expect it to chip off more easily than the KBS product. If i were not doing it the lazy way-I'd choose the KBS Rust Seal (same product as POR15-just made in Australia and cheaper to buy). |
Author: | slacko [ Tue Feb 06, 2018 9:53 pm ] |
Por 15 is not uv tolerant and will dull off if exposed to sun ( uv ) that is one reason I went over it with chassis black not that the subframes see much sun light powder coat chips and then starts to peel my preference only , I don't like powder coat Mark |
Author: | Morbo28 [ Wed Feb 07, 2018 10:32 am ] |
Same, if you're worried about fading, use the chassis black top coat. I found it far superior to powder coating in my experience, particularly for something that can get but by rocks etc. My powder coating experience has included chipping and more fragile than POR15. But at the end of the day regardless of whether you ask about coating, oil, radiator etc, on a forum you will get a range of responses from people and each will believe their method is the best ![]() Sent from my Pixel 2 XL using Tapatalk |
Author: | cooperess [ Wed Feb 07, 2018 10:47 am ] |
My opinion. Once powder coat peels there's no stopping it. |
Author: | zulu_warrior1976 [ Wed Feb 07, 2018 10:49 am ] |
Do sand blasting companies apply POR 15? Or is that a “self application” activity? Sent from my iPhone using Tapatalk |
Author: | winabbey [ Wed Feb 07, 2018 11:02 am ] |
Morbo28 wrote: ... not unlike religion. But owning and working on a Mini is a religion, isn't it? Don't we all worship the hallowed ground our Mini stands on? A Mini badge is like a high priest, to be held in reverent esteem, and the S badge is the deity at the pinnacle to be exalted, much like the Dalai Lama in the Buddhist faith (or Mr. Bridger in The Italian Job). ![]() |
Author: | Morbo28 [ Wed Feb 07, 2018 12:03 pm ] |
Haha winnabbey. Zulu - the sandblaster I have used asked what finish I wanted. I selected just etch primer (not a great choice I have learned). But I got the impression he would apply other coatings if I so desired. I guess it'll depend on the shop. Sent from my Pixel 2 XL using Tapatalk |
Author: | Kennomini [ Wed Feb 07, 2018 6:54 pm ] |
I painted both my frames with POR15, the rear one is holding up but the entire front one is peeling off and wrinkling around the MC's. I won't use it again. I'm not upset with the product I just will try something else now. |
